For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
frame relay
Hi all
what is the bandwidth of frame relay links, is it 2048mb, and can you apply this to ethernet, serial interfaces etc ?
  • Other Network Infrastructure Subjects
Re: frame relay
There is as such no specific bandwith for Frame Relay.You can configure on serial interface only
regards
Neo
Re: frame relay
what can frame relay handle then, ? also is the max bandwidth of a serial link 2 megabits
Re: frame relay
Depending on where you are, FR Access speed limit is 2048Kb/s (E1) or 1544Kb/s (T1) configured on Serial interface only. Your service provider can give you anything below that. If you need more then ATM or L2 Metro Ethernet (which you can apply to ethernet)would be better choice.
Re: frame relay
Cant FR have more than E1/T1 speeds?i was in impression that FR can work more than that also , if u have required things like bw and HSSI interface.
regards
Neo
Re: frame relay
any help
Re: frame relay
high speed frame relay service is indeed available from certain providers (e.g. MCI). Have a look at the link below, which contains a sample contract (scroll dwon to somewhere halfway down the page, it lists the different Frame Relay speeds offered, and the respective prices):
http://contracts.onecle.com/intercept/worldcom.svc.2002.04.21.shtml
HTH,
GNT
133
