Frequent failure of NM-16AM module
paneer.r
It is found NM-16AM module ports are getting failed frequently. Pls let me know anybody facing the same problem and any remedy to resolve the issue.
thisisshanky
Level 11
Level 11
Can you type in what kind of syslog messages you are getting. Also the model of router, the IOS version ( show version/ show diag) should help in further analysis. Does the router crash often ? If so, use Output Interpreter at CCO to decode the output of the crash.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
