Frozen router problem
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
Hi All,
I have encountered the following problem with a 3600 (config below) Freezing and not passing any taffic. this has happend on anumber of occasions. I have shortened the access list which is slightly longer.
Any ideas of possible causes
Thanks in advance
Current configuration : 20304 bytes
version 12.1
service nagle
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service sequence-numbers
hostname XXXXXXXXX1
enable secret 5 --moderator edit--
username XXXXXXXXX1 password 7 --moderator edit--
username XXXXXXXXXXX password 7 --moderator edit--
ip subnet-zero
no ip finger
no ip domain-lookup
ip inspect name conferencing tcp
ip inspect name conferencing ftp
ip inspect name conferencing http java-list 51
ip audit notify log
ip audit po max-events 100
isdn switch-type basic-net3
interface Ethernet0/0
no ip address
shutdown
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
no ip address
shutdown
interface BRI1/0
no ip address
shutdown
interface BRI1/1
no ip address
shutdown
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface Ethernet2/0
description Connection to XXXXXXXXXXX
ip address XXXXXXXXXXX 255.255.255.0
ip access-group 101 in
ip access-group 102 out
ip inspect XXXXXXXXXXX in
ip ospf message-digest-key 10 md5 7 --moderator edit--
interface Serial2/0
description Kilostream connection to XXXXXXXXXXX
no ip address
shutdown
interface Ethernet2/1
description Connection to XXXXXXXXXXX NAT router via ethernet
ip address XXXXXXXXXXX 255.255.255.252
load-interval 30
interface Serial2/1
no ip address
shutdown
interface BRI3/0
no ip address
ip inspect XXXXXXXXXXX out
encapsulation ppp
dialer rotary-group 1
dialer priority 255
no cdp enable
interface BRI3/1
no ip address
encapsulation ppp
dialer rotary-group 2
dialer priority 255
no cdp enable
interface BRI3/2
no ip address
encapsulation ppp
dialer rotary-group 3
dialer priority 255
no cdp enable
interface BRI3/3
no ip address
shutdown
interface Dialer1
ip access-group 102 in
ip access-group 101 out
ip directed-broadcast
encapsulation ppp
no keepalive
dialer in-band
dialer idle-timeout 1800
dialer string XXXXXXXXXXX
dialer load-threshold 60 either
dialer-group 5
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer2
description ISDN connection to XXXXXXXXXXX
ip inspect conferencing out
encapsulation ppp
no keepalive
dialer in-band
dialer idle-timeout 300
dialer-group 6
no cdp enable
ppp multilink
interface Dialer3
description Backup ISDN to XXXXXXXXXXX
encapsulation ppp
no keepalive
dialer in-band
dialer-group 6
no cdp enable
ppp multilink
router ospf 323
log-adjacency-changes
area 3 authentication message-digest
redistribute connected metric 1 metric-type 1 subnets
redistribute static metric 1 metric-type 1 subnets
network XXXXXXXXXXX.0 0.0.0.255 area 3
ip classless
ip route XXXXXXXXXXX 255.255.255.128 XXXXXXXXXXX
ip route XXXXXXXXXXX 255.255.255.128 XXXXXXXXXXX 250
no ip http server
access-list 51 permit any
access-list 71 permit XXXXXXXXXXX
access-list 101 permit ospf any any
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.255 any eq 5750
access-list 101 permit tcp XXXXXXXXXXX 0.0.1.255 any eq 5750
access-list 101 permit tcp XXXXXXXXXXX 0.0.3.255 any eq 5750
access-list 101 permit tcp XXXXXXXXXXX 0.0.255.255 any eq 5750
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.31 any eq 5750
access-list 101 permit tcp XXXXXXXXXXX0.0.255.255 any eq 5750
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.15 any eq 5750
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.255 any eq www
access-list 101 permit tcp XXXXXXXXXXX 0.0.1.255 any eq www
access-list 101 permit tcp XXXXXXXXXXX 0.0.3.255 any eq www
access-list 101 permit tcp XXXXXXXXXXX 0.0.255.255 any eq www
access-list 101 permit tcp XXXXXXXXXXX.0 0.0.0.255 any eq www
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.31 any eq www
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.15 any eq www
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.255 any eq 1433
access-list 101 permit tcp XXXXXXXXXXX 0.0.1.255 any eq 1433
access-list 101 permit tcp XXXXXXXXXXX 0.0.3.255 any eq 1433
access-list 101 permit tcp XXXXXXXXXXX 0.0.255.255 any eq 1433
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.31 any eq 1433
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.15 any eq 1433
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.255 any eq 1073
access-list 101 permit tcp XXXXXXXXXXX 0.0.1.255 any eq 1073
access-list 101 permit tcp XXXXXXXXXXX 0.0.3.255 any eq 1073
access-list 101 permit tcp XXXXXXXXXXX 0.0.255.255 any eq 1073
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.31 any eq 1073
access-list 101 permit tcp XXXXXXXXXXX172.25.22.16 0.0.0.15 any eq 1073
access-list 101 permit tcp XXXXXXXXXXX 0.0.0.255 any eq telnet
access-list 102 permit ospf any any
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any traceroute
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any packet-too-big
access-list 102 permit icmp any any unreachable
dialer-list 5 protocol ip permit
dialer-list 6 protocol ip permit
snmp-server community btconf RO
snmp-server location XXXXXXXXXXX
snmp-server contact XXXXXXXXXXX
snmp-server chassis-id XXXXXXXXXXX
banner motd ^CC*** NO UNAUTHORISED ACCESS ***
^C
line con 0
exec-timeout 30 0
logging synchronous
login
transport input none
line aux 0
line vty 0 4
access-class 71 in
exec-timeout 30 0
login
Re: Frozen router problem
That is because of high cpu on a router. We need to see which process is hogging the cpu of the router. So for that you need to plug the console on a router and leave it and hopefully router will exhibit some indication (like tracebacks) about process spiking the cpu.
Also try to moniter the box using "sh proc cpu" and see what process is spiking it when cpu goes near 90 to 99%.
Hi there,
I have telneted into the router and had a look at the CPU, the highest usage is :
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
25 913040 992092 920 0.57% 0.73% 0.72% 0 IP Input
Your previous statment (plug the console on a router and leave it) do I need to have any thing else running while hyper terminal is up ?
Also not sure what you mean when you say trace backs.
When you issue "sh proc cpu" you need to see the first line where it reports the cpu usage in general with 1, 5 min avg etc. If that is beyond 80% for 5 min average, its a problem so after that you need to start seeing the processee which is hogging it.
Here is the url for troubleshooting high cpu on a router.
http://www.cisco.com/warp/public/63/highcpu.html
Now leave the console plugged in. Router will exhibit some error messages or some indication during high cpu on a console. Also remove "logging synchronous" from the line con 0.
105
