Community Member
Frozen Router Problem
Hi All,
I recently encountered a problem with a 3600 series router whereby a while trying to bring up a BRI onterface with the command "no shutdown" my telnet session froze and I could not re-establish a telnet connection, On further investigation I found that the router had stopped passing traffic through all its interfaces. The solution was to reboot the router.
Does any one know why a simle command as "no shutdown" would cause this
Further info: we had two newly installed ISDN 2's connected to the BRI ports.and prior to to them being installed test calls wrer made from the ISDNs
Re: Frozen Router Problem
It's possible that when you brought the BRI interface up a call was placed and the routing table was changed effecting your telnet session.
The freezing isn't normal and might have be an IOS issue or could have a one-time event. If thats really what happened. Might be hard to find out after the event.
Having the config of the router would give us a idea of what could have happened.
Community Member
Thanks for your quick response,
The freezing has occurred on two seperate occasions and actually only happened when I tried to bring up the BRI1/1 interface the config for the router is quite big so I have attached the additons which were made to add the two new dialers BRI''s etc.
I was unaware the BRI would place call when it is brought up, I thought a ping would initiate traffic and cause the dialer to dial out.
version 12.1
interface BRI1/0
no ip address
ip inspect ************ out
encapsulation ppp
dialer rotary-group 3
dialer priority 255
isdn switch-type basic-net3
no cdp enable
interface BRI1/1
no ip address
encapsulation ppp
dialer priority 255
no cdp enable
interface Dialer4
description Connection to ************
ip address ************ 255.255.255.252
ip access-group 102 in
ip access-group 101 out
ip directed-broadcast
encapsulation ppp
no keepalive
dialer in-band
dialer idle-timeout 1800
dialer string ************
dialer load-threshold 60 either
dialer-group 5
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer5
encapsulation ppp
no keepalive
dialer in-band
dialer-group 5
no cdp enable
ppp multilink
ip route ************** 255.255.255.0 Dialer4
Community Member
Do you have other dialer interfaces or is this it , just wondering why the dialer interfaces don't tie into the physical BRI interfaces (dialer rotary-group number should match the virtual dialer interface number).
Have you configured the dialer-list 5 for call triggering.
Have you tried shutting the dialer interfaces first and then opening the BRI ports.
Are you running any debugs as the router freezes?
Community Member
Yes we do Dialer interfaces 1,2,3, 4+5 will be the new ones
Sorry had fat fingers on the privious config:
interface BRI1/0
no ip address
ip inspect ********** out
encapsulation ppp
dialer rotary-group 4
dialer priority 255
no cdp enable
interface BRI1/1
no ip address
ip inspect ********* out
encapsulation ppp
dialer rotary-group 5
dialer priority 255
isdn switch-type basic-1tr6
no cdp enable
Dialer list 5 is as follows:
dialer-list 5 protocol ip permit
Debug is switched off.
I will try shutting down the dialer interfaces down first and bringing up the BRI's
Although I will have to wait and do this out of hours.
155
