FTP is issue
We have ftp server were client can upload and download logs if they are having issue.But the biggest problem is due to that our T1 get max out and people are experiencing problem with our internet and this also effects our HTTP server from outside.have tried QOS on eternal router by
queue-list 1 protocol ip 1 tcp www
queue-list 1 protocol ip 2 udp domain
queue-list 1 default 3
queue-list 1 queue 1 byte-count 7500
queue-list 1 queue 2 byte-count 500
queue-list 1 queue 3 byte-count 2000
and applied to the serial interface
custom-queue-list 1
But the issue is still there what is the best way to do and how ?
Thanks and Regards
Bhavin
Re: FTP is issue
Can you tell where this custom-queue is configured? To me it should be located on the serial side of the router which is connected to your servers on the LAN side.
Also probably your MTU on this WAN link is about 1500 bytes and you'd better write your byte-count numbers as multiples of 1500 (because you say 2000 and after the first 1500 byte packet is removed from the queue there's a capacity for 500 bytes and if the second packet in the queue is greater than 500 bytes - say 1500 interface doesn't fragment this packet, eventually you reserve 3000 bytes capacity for this queue.)
Another more easily configured and controllable QoS solution will be CBWFQ but ALL these are solutions supposing that you experience congestion during short periods of times. If thw WAN link is constntly congested I think you've nothing to do other than increasing the bandwidth.
Regards.
VIP Purple
Re: FTP is issue
Hello Bhavin,
I would use class-based weighted fair queueing and prioritze all other traffic over the FTP traffic, the configuration would look like this:
Router#conf t
Router(config)#class-map match-all ANYTRAFFIC
Router(config-cmap)#match access-group 101
Router(config-cmap)#exit
Router(config)#class-map match-all FTP
Router(config-cmap)#match access-group 102
Router(config)#access-list 101 deny tcp any any eq ftp
Router(config)#access-list 101 deny tcp any any eq ftp-data
Router(config)#access-list 101 permit ip any any
Router(config)#access-list 102 permit tcp any any eq ftp
Router(config)#access-list 102 permit tcp any any eq ftp-data
Router(config)#access-list 102 deny ip any any
Router(config)#policy-map PRIORITY
Router(config-pmap)#class ANYTRAFFIC
Router(config-pmap-c)#set precedence 5
Router(config-pmap-c)#exit
Router(config-pmap)#class FTP
Router(config-pmap-c)#set precedence 4
Router(config-pmap-c)#end
Router#conf t
Router(config)#interface FastEthernet0
Router(config-if)#service-policy output PRIORITY
I am assuming that your interface is a FastEthernet, if it is another one it doesn´t matter, just apply the service policy to the interface that your hosts connect to.
With this configuration, all other traffic is prioritized over FTP traffic.
Use the command:
show policy-map interface FastEthernet0
to check that FTP packets get another (lower) priority than all other traffic.
Let me know if that is not 100% clear...:)
Georg
187
