07-03-2003 07:36 PM - edited 03-02-2019 08:37 AM
pc1-----2950-----2621xm--------7513------6509-----pc2
when pc1 ftp to pc2.It can get files and put small files.It can't put large size files.
2621xm connect to 7513 with frame-relay by serial interface.
The mtu on 2621xm and 7513 serial interface is 1500.
why?
07-03-2003 08:34 PM
What error are you getting on the ftp client/ server, when you try to transfer a large file ??? What is the max size of the file that you were able to transfer???
07-03-2003 09:47 PM
on client£ºconnection has been closed by remote host.
I don't know the max size of the file.
when i try to transfer a file that is 3k.,it's a fail.
07-03-2003 10:42 PM
Is the client getting disconnected, each time you try to send a file above 3k size ?? Do you face the same problem, from a differnt pc/ same ftp client ???
07-03-2003 11:38 PM
it has same problem on different pc/same ftp client .if i transfer a file smaller 1k.it is successfully.
07-04-2003 12:15 AM
To rule out, possibilities of a software problem ( the ftp software you are using), Can you try a different client such as windows ftp client or leap ftp and see if the result is same ?
07-04-2003 01:34 AM
i am running ftp command in win98
