Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
full-flow-control
what's the difference between duplex full and duplex
full-flow-control, which has the better performance?
thanks.
1 REPLY
Re: full-flow-control
Assuming that this quesiton refers to Fast / Gigabit Ethernet - the difference between full-duplex and full-duplex flow-control is that:
Essentially, in the latter, 802.3x flow control would be enabled. This enables a device to respond to and/or iniate 'pause' frames to/from the link partner. Consequently the transmitter temporarily reduces the amount of data being sent. This is done to prevent buffer-overflow (dropped packets) on the receiver. UniverCD will provide config details and defaults for each platform/sw type - for example on the cat6000 check out the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_6_3/cmd_ref/set_po_r.htm#30647
The question of better performance depends.... If the implementation can handle it ie both end devices have enough 'horsepower' to process the tx/rx rates, then full-duplex alone is faster. However, if there is an issue wrt buffering/horsepower rates, then flow-control may help prevent packet drops and the resulting time spent in packet re-transmission.
rgds
steve
151
