Dear All,
Im having a problem on 6513 catalyst switch, lets say I have 4 VLANs so I had created the VLANs on the switch and then configured the interfaceVLANs and the IP addresses and the routing is done correctly between VLANs, all PC/Servers in different networks ping each other. I also had DHCP server in my server farm. So IP Helper-address was configured under every interfaceVLANs to point to the DHCP server and all clients in different VLANs got their IPs from the DHCP correctly. I also had a Firewall Blade module installed in the catalyst 6513 core switch.
My question/problem is how to configure this FW Blade module with the equivalent command to the IP helper-Address??
Thanks..
Tamer Bayomy
