The 3550G comes with 10 module ports, Is there a fiber module for one of the ports that supports fiber at 100mbs or can you only get the Gbic modules that support fiber 1000 only?
I have a remote site that I need to use fiber on and am looking for a Media convertor on the far end to convert the fiber link to RJ45 connection. But when I bring it back to the 3550G unless it is a 1000Base Media convertor I do not see a solution for this other than purchasing 2 of the media convertors and utilizing a 10/100 port on one of the other switches. I would prefer to connect directly into the 3550G with the fiber and save the cost of another transeiver.
Any comments would be appriciate.
Thanks.
