12-23-2003 11:59 PM - edited 03-02-2019 12:32 PM
dera friends
i have gigastacking modules in two cases between cisco2924 and 2950 switches and in one case gigastckingis done between a module on 2924 and gigasint on 2950 12 port switch withei software
the problem is that the duplex on gbic likbks has gone to half duplex on auto negotition on all switch giga modules
also in case where i have 12 port 2950 switch with 2 gbic int if i do duplex to full forcefully on 2924 side i am not able to telnet to the 12 port switch as well as network gets break
can u suggest me any solution to it
thanx
vishal
12-29-2003 12:51 AM
which IOS and/or CatOS versions are you using ? This could be a software bug. Can you post the configs of both switches ?
GP
12-29-2003 10:52 PM
Are these point to point connections? The GBICs only support half-duplex when cascaded.
Reference - Cisco - GBIC Data Sheet -
http://www.cisco.com/en/US/products/hw/modules/ps872/products_data_sheet09186a00800a1789.html
