Community Member
GEC and dot1Q on 6500 sups
I have (2) links set up between a pair of 6500 chassis configured for GEC and dot1Q. If for whatever reason one of the fiber pairs goes errdisable, should the remaining link automatically revert to a single dot1Q trunked link?
This doesn't seem to be the case and am having to make the case for redundancy vs. load balancing.
Re: GEC and dot1Q on 6500 sups
It depends on the version of software you have, prior to 6.3 it would unbundle the link and revert to a single connection causing the port to go through the listening / learning / forwarding process. From 6.3 the link remains as part of a 1 port bundle thus avoiding the listening / learning / forwarding process.
· EtherChannel enhancements
An EtherChannel is preserved even if it contains only one port. In software releases prior to 6.3(1), if you have a 2-port channel and one link is removed, the remaining link is removed and added back to spanning tree, which causes a loss of connection on the channel until the link is forwarding again.
Community Member
That being the case it looks like there are other issues that may be causing the link to stay down and not re-initiate. When one link goes down usually both links go down but never come back up. It requires a manual intervention. I'll have to look at the errdisable log next time it happens.
There is set command that will try to bring up the errdisable port after a configured amount of time but this off by default .
