Webcast-Catalyst9k
giant frame problem/input errors
Hi, long time reader first time poster desparate for a bit of advice
Stuck on an issue when trunking between Cat5509 and Cat4507R. ISL trunk, both sides set to on, full duplex, 100 Mb, same native vlan. Getting the following output on the Cat4507r:
FastEthernet3/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet Port, address is 000b.be6d.af40 (bia 000b.be6d.af40)
Description: UTP/Fibre link to CARSWC2
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 249/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input 00:00:00, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 117000 bits/sec, 40 packets/sec
5 minute output rate 4000 bits/sec, 4 packets/sec
92728 packets input, 31405768 bytes, 0 no buffer
Received 92728 broadcasts (0 multicast)
0 runts, 8647 giants, 0 throttles
8647 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
13823 packets output, 2350122 bytes, 0 underruns
Giants = input errors. I can't work out why this is happening! I'm unable to change MTU size on 100Mb interface.
In case it's any use, the 5509 side displays the following:
carswc2> (enable) sh port 5/3
Port Name Status Vlan Level Duplex Speed Type
5/3 FX_LINK_TO_CARSWC6 connected trunk normal full 100 100BaseFX MM
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
5/3 disabled shutdown 0 0 1 enabled 31
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
5/3 0 - - - - -
Port Broadcast-Limit Broadcast-Drop
5/3 - -
Port Status Channel Admin Ch
Mode Group Id
5/3 connected off 19 0
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
5/3 0 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
5/3 0 0 0 0 0 0 -
Last-Time-Cleared
Thu Feb 6 2003, 16:02:26
carswc2> (enable) sh mac 5/3
Port Rcv-Unicast Rcv-Multicast Rcv-Broadcast
5/3 0 567690 0
Port Xmit-Unicast Xmit-Multicast Xmit-Broadcast
5/3 0 5735511 0
Port Rcv-Octet Xmit-Octet
5/3 91402530 3762619305
MAC Dely-Exced MTU-Exced In-Discard Lrn-Discrd In-Lost Out-Lost
5/3 0 - 109 0 0 0
Last-Time-Cleared
Does anyone have any idea why this could be happening?
It may also be worth noting that there is a fibre/ethernet media convertor between the 2 switches. The Cat 5509 port is FX, Cat 4507R port is TX.
1 REPLY
Re: giant frame problem/input errors
A couple of questions:
For how long are you having this problems?, if recently what where your last changes?
Input error usually means physical error. Did you check your physical media already?
I also saw in your post that the amount of giant packets actually correspond to the amount of broadcast. Have used a Proto analyzer in order to see what's the BCast all about?
Hope you reply in order to help u!!!
401
