Gig EtherChannel between two Cat 4006s
I need to create a Gig ether channel between tow 4006s. I don't want to select two port on the same blade though, in case the one blade goes down.
Can I generate a Gig ether channel with 2 Gig ports on two separate blades?
I have SUP IV engines on the switches.
Re: Gig EtherChannel between two Cat 4006s
Referencing the configuration guide for IOS 12.1(13) on the Cat 4006:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_13/config/channel.htm#1020363
It says:
" You can form an EtherChannel with up to eight compatibly configured Ethernet interfaces across modules in a Catalyst 4000 family switch. "
Also in the guidelines and Restrictions section:
"All Ethernet interfaces on all modules support EtherChannel (maximum of eight interfaces) with no requirement that interfaces be physically contiguous or on the same module. "
So it should work fine.
LW
Alex.
81
