Community Member
Giga stacking on 3550 switches
We have two WS-C3550-24-PWR connected together with Cisco systems GigaStack® Gigabit Interface Converter (GBIC), two, one on each switch connected over a Cisco provided Gigastack cable. The problem is a lot of collisions noticed about 1 collission per megabyte transmitting the Gigastack
interfaces. The interfaces are negotiating to 1 Gb/s half-duplex, we believe the problem to be associated or related to the duplex setting. Cisco's
website states that we can get a negotiation to 2 Gb/s full duplex if we configure the two stand-alone switches in a star topology instead of leaving
the default cluster topology. Can anyone verify this possiblity and recommend the (I believe global) commands to do this.
thanks,
Sujohn
-London
1 ACCEPTED SOLUTION
Re: Giga stacking on 3550 switches
Hi Sujohn,
Have a look at this link and you will get a complete picture with topology how the cascaded and point to point giga stak look like
http://www.cisco.com/en/US/products/hw/modules/ps872/products_data_sheet09186a00800a1789.html
HTH, if yes please rate the post.
Ankur
No command, it's the way the switches are stacked using the gigastack.
GigaStack-to-GigaStack cascade connections operate in half-duplex mode, and GigaStack-to-GigaStack point-to-point connections operate in full-duplex mode.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/scg/swint.htm
Community Member
Thanks but how do you differenciate between a GigaStack-to-GigaStack cascade connection and GigaStack-to-GigaStack point-to-point connection.
thanks for the replies
Sujohn
-London
cascade is 3550---3550---3550
point to point is 3550---3550
3550
or
3550-----3550-----3550
do you see the difference?
Hi Sujohn,
Ankur
202
