Webcast-Catalyst9k
Gigabit Etherchannel problem
When configuring Gigabit Etherchannel (PAGP) Between Catalyst 4006 (SUP3, IOS 121-13.EW1) and Catalyst 6509 [SUP2 + MSFC2, CatOS 7.3(2) + MSFC2: 12.1(11b)E4.
We are using the 18 port Gigabit module on Catalyst 4006 "WS-X4418" and port 2/1,2/2,2/17 and 2/18.
we are getting on Catalyst 4006 log this
Jun 25 22:06:20: %EC-5-L3DONTBNDL2: GigabitEthernet2/17 suspended: incompatible partner port with GigabitEthernet2/1
Jun 25 22:06:20: %EC-5-L3DONTBNDL2: GigabitEthernet2/18 suspended: incompatiblepartner port with GigabitEthernet2/1
Config:
interface Port-channel1
switchport
switchport access vlan 78
switchport mode access
no snmp trap link-status
interface GigabitEthernet2/1
channel-group 1 mode desirable
interface GigabitEthernet2/17
interface GigabitEthernet2/18
Sh int g2/17 eth
Local information:
Hello Partner PAgP Learning Group
Port Flags State Timers Interval Count Priority Method Ifindex
Gi2/17 SC U6/S7 H 30s 1 128 Any 0
Partner's information:
Partner Partner Partner Partner Group
Port Name Device ID Port Age Flags Cap.
Gi2/17 TBM06201197(EC65M40- 0009.b61f.c236 6/1 28s SC 12
1 REPLY
Re: Gigabit Etherchannel problem
Ports 1 and 2 on the WS-X4418 are dedicated uplink ports and each have a dedicated 1Gbps - full duplex to the backplane. The other 16 oversubscribed ports are grouped in sets of four ports each. Each set of four ports shares 1Gbps - full duplex to the backplane.
My guess is that you can't group the dedicated ports with the oversubscribed ports.
From Cisco Docs:
The oversubscribed Gigabit ports are designed for end-station connections. Cisco does not recommend connecting these ports to switches or routers.
Each group of four oversubscribed ports has a buffer for incoming frames to allow connected devices to transmit traffic simultaneously. Because the inbound buffer is small, the default (and recommended) flow-control configuration for the oversubscribed ports is receive desired and transmit on.
You can bundle multiple oversubscribed ports into a Gigabit EtherChannel link to connect to channel-capable servers. By bundling multiple oversubscribed ports in the same port group, you might increase the total available bandwidth as compared to using a single link. However, it does provide redundancy with quick failover for links to servers and hosts that support the Port Aggregation Protocol (PAgP).
115
