Webcast-Catalyst9k
Gigabit Fiber Connectivity for 3548 Switch
I attached two IBM Netfinity's (Fiber connection) to the fiber connection of my Cisco 3548 Switch. I clocked the upload and download speed and it is still the same, about 100MB max. So I updated the Gigabit drivers on the IBM Netfinity. I still get the same results. Do I need to do enable anything on the switch? Do I need to type in any commands to get full fiber connectivity??
Please advice. Thanks.
Re: Gigabit Fiber Connectivity for 3548 Switch
I cant think anything on the switch to configure. By the way how are you testing this performance?
I downloaded a 2GB file and timed it. First, was using the 10/100 connection and then I switched to the fiber connection. Same speed or time resulted from this experiment. Am I doing it wrong?
171
