Gigabit optical cable connectivity
I wand to connect two locations using optical cable betwwen them. What is the best way to do that? Using OC-3 module in router (3600 series) or using gigabit module in switch (2900), or something else? Distance is 2-3 km.
Thanks!
Re: Gigabit optical cable connectivity
I am a network design engineer for Sprint...
See if you can get an OC-3 LR (Long Reach) card. GigE and OC-3 are two very different speeds (155mb vs. 1.0mb).
What are you trying to accomplish?
JS
Just connect two locations with optical cable between them. If it is possible I would like gigabit. So can I do that with some module on 2900 switch?
Thanks!
I think you can if you buy the necesary modules.
http://www.cisco.com/univercd/cc/td/doc/pcat/ca2900.htm
But take care about distances between locations when you buy the GBIC.
We use for gigabit connection several 2924 and it works very whell.
Otto
92
