Community Member
GRE tunnel over to equal path and policy routing
Hi All,
I need enable policy routing with set ip next hop, but I want to use load balancing per packet with two equal paths for that. As in policy routing can be only one active ip next hop and it have to be adjacent router I decide first to build tunnel interface which uses both of two paths. Without policy routing it works fine I can see that the GRE packets are loadbalanced per packet but when I enable policy routing the tunnel takes always only one path. I use no fast switched policy cache. I use CEF, I also tried "ip cef load-balancing algorytm tunnel" but nothing works. Any ideas? Thanks
1 REPLY
Re: GRE tunnel over to equal path and policy routing
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
143
