GSS-4492 initial configuration problems
I have a customer who purchased two GSS-4492s a few months ago not realizing they were end of life. So far, they haven't had time to configure and install these and asked me to help out. I've gone through the configuration and admin guides, but it isn't working. An nslookup always returns "Can't find blah.domain.com". I've attached the configuration. Can someone please scan this and see if there is an obvious error? I've not been able to find a working configuration that I can reverse engineer, but I know something isn't quite right. Thank you.
gss1.domain.com#sh runn
interface ethernet 0
   ip address 10.10.115.5 255.255.255.0
   gss-communications
interface ethernet 1
   ip address 10.10.99.52 255.255.255.0
hostname gss1.domain.com
ip default-gateway 10.10.115.1
ip name-server 10.10.100.111
ip name-server 10.10.100.110
ip name-server 10.10.100.102
ssh enable
no ssh keys
no ssh protocol version 1
telnet enable
ntp enable
snmp-server trap-source ethernet 0
ntp-server 199.182.221.110
ntp-server 192.95.20.208
no cnr enable
drp
    no enable
terminal-length 23
exec-timeout 150
logging disk enable
logging disk priority Notifications
no logging host enable
logging host priority Warnings
logging facility local5
tacacs-server timeout 5
tacacs-server callerId-info-type hostname
tacacs-server keepalive-enable
gss1.domain.com(config-gslb)#show gslb-config
region "Central USA" comments "Central USA Region"
region "Eastern USA" comments "Eastern USA Region"
region "Western USA" comments "Western USA Region"
owner System
location "Broken Arrow" region "Central USA"
location "Oklahoma City" region "Central USA"
gss-device gss1.domain.com activate
source-address-list Anywhere owner System
        ip address  0.0.0.0 0.0.0.0
        ip address  ::/0
domain-list DOMAIN-LIST-BA owner System
        domain SERVER02.domain.com
domain-list DOMAIN-LIST-OKC owner System
        domain www.domain.com
        domain SERVER01.domain.com
keepalive-properties scripted-kal standard min-interval 40
keepalive-properties icmp standard min-interval 40
keepalive-properties tcp standard min-interval 40 port 80 termination reset timeout 20
keepalive-properties http-head standard min-interval 40 port 80 termination reset timeout 20 path /
keepalive-properties https-head standard min-interval 40 port 443 SSL-Version TLSV1  timeout 20 path /
keepalive-properties kalap standard min-interval 40 capp-key hash-not-set circuit-retry-count 1
keepalive-properties cra timing-decay 2 min-interval 10
keepalive-properties ns query-domain . min-interval 40
keepalive-properties global vip-keepalive enable
keepalive-properties global cra-keepalive enable
keepalive-properties global ns-keepalive enable
proximity-properties
        no enable
        mask 255.255.255.255
        prefix-length 128
        timeout 4320
        equivalence 20
        refresh-interval 8
        discovery-sequence ICMP
        acceptable-rtt 100
        acceptable-zone 40
        no wait enable
        no authentication drp enable
        no fallback-probe-method path-probe
sticky-properties
        no enable local
        no enable global
        timeout 60
        prefix-length 128
geodb-properties
        no enable
        timeout 4320
        equivalence 1000
        acceptable-distance 5000
        no request-monitoring enable
no manual-reactivation enable
answer vip 10.10.115.1 name test.domain.com location "Oklahoma City" manual-reactivation disable activate
        keepalive type icmp ip-address 10.10.115.1
answer vip 10.10.200.154 name SERVER02.domain.com location "Oklahoma City" manual-reactivation disable activate
        keepalive type icmp ip-address 10.10.200.154
answer vip 10.11.200.154 name SERVER01.domain.com location "Broken Arrow" manual-reactivation disable activate
        keepalive type icmp ip-address 10.11.200.154
answer ns 206.188.198.27 disable name ns54.worldnic.com manual-reactivation disable activate
answer ns 207.204.40.127 disable name ns53.worldnic.com manual-reactivation disable activate
answer vip 192.168.135.150 name WWW.domain.com location "Oklahoma City" manual-reactivation disable activate
        keepalive type http-head port 80 termination graceful ip-address 192.168.135.150
answer-group DC-STAGING-BA owner System type vip
        answer-add 10.11.200.154 name SERVER01.domain.com weight 1 order 0 load-threshold 254 activate
answer-group DC-STAGING-OKC owner System type vip
        answer-add 10.10.200.154 name SERVER02.domain.com weight 1 order 0 load-threshold 254 activate
        answer-add 192.168.135.150 name WWW.domain.com weight 1 order 0 load-threshold 254 activate
dns rule DC-STAGING-BA-DNS owner System source-address-list Anywhere domain-list DOMAIN-LIST-BA activate
        query a
        clause 1 vip-group DC-STAGING-BA method least-loaded  ttl 20 count 1 manual-reactivation disable  activate
dns rule DC-STAGING-OKC-DNS owner System source-address-list Anywhere domain-list DOMAIN-LIST-OKC activate
        query a
        clause 1 vip-group DC-STAGING-OKC method least-loaded  ttl 20 count 1 manual-reactivation disable  activate
Everyone's tags (1)
57
