You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
hard problem of eigrp summary
I config "ip summary " on s1/0:1,but why ios can't generate summary of 10.72.0.0/16 and can generate summary of 10.71.0.0/16 ?
RTA#sh ip eigrp int
IP-EIGRP interfaces for process 1
Xmit Queue Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Fa0/0 1 0/0 1 0/10 50 0
BR0/0 0 0/0 0 5/10 0 0
Fa0/1 1 0/0 1 0/10 50 0
Se1/0:1 1 0/0 50 0/12 216 0
Lo0 0 0/0 0 0/10 0 0
RTA#sh int f0/1
FastEthernet0/1 is up, line protocol is up
Hardware is AmdFE, address is 0001.96db.0701 (bia 0001.96db.0701)
Internet address is 10.72.195.1/30
RTA#sh run int s1/0:1
Building configuration...
Current configuration:
interface Serial1/0:1
bandwidth 1984
ip address 10.1.1.30 255.255.255.252
ip summary-address eigrp 1 10.72.0.0 255.255.0.0 5
ip summary-address eigrp 1 10.71.0.0 255.255.0.0 5
ip mroute-cache
end
RTA#sh ip eigrp to 10.71.0.0 255.255.0.0
IP-EIGRP topology entry for 10.71.0.0/16
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 28160
Routing Descriptor Blocks:
0.0.0.0 (Null0), from 0.0.0.0, Send flag is 0x0
Composite metric is (128256/0), Route is Internal
Vector metric:
Minimum bandwidth is 10000000 Kbit
Total delay is 5000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1514
Hop count is 0
RTA#sh ip eigrp to 10.72.0.0 255.255.0.0
% Route not in topology table
  • Other Network Infrastructure Subjects
Silver
Re: hard problem of eigrp summary
you can summarize both by
ip summary-address eigrp 1 10.71.0.0 255.254.0.0 5
I can't do because 10.71.0.0/16 is production .
If I do "ip summary-address eigrp 1 10.71.0.0 255.254.0.0 5 ", and ios don't generate the summary route , maybe I will say goodbye to my boss.
thanks.
Deilert,
Wouldn't you be defining 10.70.0.0 & 10.71.0.0 with the 255.254.0.0 mask?
Gold
Could you post a show ip route 10.72.0.0 255.255.0.0 longer and a show ip route 10.71.0.0 255.255.0.0 longer, if it's not too much information. It seems like it should be summarizing, since you have at least one interface in the range.
Are you using an admin distance on the end of the summary for a reason? I know that 5 is low, but it could be that you have a lower admin distance static or connected in this range knocking the summary out (though this normally wouldn't cause the summary not to be built, but rather just prevent it from being installed in the routing table). Could you try it without the admin distance?
Russ.W
There are static route for 10.71.0.0/16 and 10.72.0.0/16,I¡¡also think it should be summarizing,so I think it maybe this bug:CSCdp93649
RTA>sh ip route 10.72.0.0 255.255.0.0 longer-prefixes
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 10.1.202.29 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 54 subnets, 10 masks
S 10.72.0.0/16 [1/0] via 10.71.5.253
C 10.72.195.0/30 is directly connected, FastEthernet0/1
RTA>sh ip route 10.71.0.0 255.255.0.0 longer-prefixes
C 10.71.5.0/24 is directly connected, FastEthernet0/0
S 10.71.0.0/16 [1/0] via 10.71.5.253
C 10.71.50.1/32 is directly connected, Loopback0
RTA>sh ip eigrp to ze
IP-EIGRP Topology Table for AS(18)/ID(10.71.5.246)
Gold
Gold
Have you tried it without the static routes? I'm not certain why you'd run both--either redistribute the statics, or configure the summaries. With the lower admin distance static route there, the EIGRP summary route isn't going to make it into the routing table, so it shouldn't be advertised to a peer anyway. The summary will block the generation of longer prefixes out that interface, but you could do that with a distribute list instead (?).
What version of code are you running? CSCdp93649 should be integrated into 12.1 and forward, from about 12.1(04) or so, looking at the record.
Russ.W
134
