Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
hard problem with isdn
I have a very big problem with isdn.I'm using a local carrier to connect to my remote office, sometimes i can connect to the carrier Pop, but the network of the provider doesn't work, so i can't connect to my remote office, but connection with local pop went right.Is there a test conditions to use with isdn to tell the router to try to ping a remote Ip and if this doesn't work to use an alternate dialer (and try to connect directely to remote office, for example)?
Thanks to all for you help
1 REPLY
Re: hard problem with isdn
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
105
