hardware compression not working - cisco 2621xm
Two Cisco 2621xm routers, ppp encapsulation on serial interfaces (T1 modules), AIM-COMPRESS2 v2 installed on each router and detected by the IOS software (sh diag 0, sh pci aim), compression enabled using compress stac caim 0 and no fair-queue, same IOS version on both routers.
sh compress displays software compression not hardware!
Any ideea what could the problem be ?
Re: hardware compression not working - cisco 2621xm
check out the following link on Data Compression AIM for the Cisco 2600 Series Routers, hope this helps :
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a0080087431.html
It could be:
- Interface is shut down
- Old IOS-software (use 12.0(7) or later)
- Bugs: CSCdk15127 [1], CSCdr47841 [2]
- Wrong syntax when using stacker (use "ppp compress
stac", not "compress stac")
You might want to take a look at the WAN Compression FAQ [3].
Hope this helps. :-)
[1]:http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdk15127
[2]:http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdr47841
[3]:http://www.cisco.com/en/US/customer/tech/tk713/tk802/technologies_q_and_a_item09186a008019be75.shtml
156
