Community Member
hardware error for NM-4A/S?????
I just got a NM-4A/S for 2611, after I installed it, my router always reboot, before reboot, there are some error message like,
Unexpected exception to CPU vector 100, PC = 800440E0
-Traceback= 800440E0 800452B4 80045314 80302290 80301BF8 8030188C 802BB1D0 802C9
C70 80355A98
=== Flushing messages (00:14:39 UTC Mon Mar 1 1993) ===
Queued messages:
Writing crashinfo to flash:crashinfo_19930301-001439
*** System received a SegV exception ***
signal= 0xb, code= 0x100, context= 0x821d7328
PC = 0x800440e0, Vector = 0x100, SP = 0x825996f8
after I removed the card, everything is ok,
who would like to tell me this is a hardware error or not ?
thanks
1 REPLY
Re: hardware error for NM-4A/S?????
Did you also check whether the IOS does support this hardware. I would think of this as a software error. Check this link and see if it helps!
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a0080189ddb.shtml
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094ae0.shtml
107
