Community Member
hardware issue?software issue ?
i received %CI-2-ENVCRIT: -12 Voltage measured at -6.43 from 7513
here's the show environment output:
WLM-RT7513-01#show environment all
Arbiter type 1, backplane type 7513 (id 2)
Power supply #1 is 1200W AC (id 1), power supply #2 is 1200W AC (id 1)
Active fault conditions: none
Fan transfer point: 1%
Active trip points: none
15 of 15 soft shutdowns remaining before hard shutdown
Dbus slots: XXXXXX
card inlet hotpoint exhaust
RSP(6) -117C/-17 -113C/-17 -112C/-16
RSP(7) -117C/-17 -114C/-17 -112C/-16
Shutdown temperature source is 'hotpoint' on RSP(6), requested RSP(6)
+12V measured at 6.50
+5V measured at 2.75
-12V measured at -6.53
+24V measured at 12.83
+2.5 reference is 1.32
PS1 +5V Current measured at 0.00 A (capacity 200 A)
PS1 +12V Current measured at 0.00 A (capacity 35 A)
PS1 -12V Current measured at 0.00 A (capacity 3 A)
PS1 output is 0 W
PS2 +5V Current measured at 0.00 A (capacity 200 A)
PS2 +12V Current measured at 0.00 A (capacity 35 A)
PS2 -12V Current measured at 0.00 A (capacity 3 A)
PS2 output is 0 W
WLM-RT7513-01#show environment last
RSP(6) Inlet previously measured at -117C/-178F
RSP(6) Hotpoint previously measured at -114C/-173F
RSP(6) Exhaust previously measured at -112C/-169F
RSP(7) Inlet previously measured at -117C/-178F
RSP(7) Hotpoint previously measured at -114C/-173F
RSP(7) Exhaust previously measured at -112C/-169F
+12 Voltage previously measured at 6.46
+5 Voltage previously measured at 2.73
-12 Voltage previously measured at -6.48
+24 Voltage previously measured at 12.73
WLM-RT7513-01#show environment table
Sample Point LowCritical LowWarning HighWarning HighCritical
RSP(6) Inlet 44C/111F 50C/122F
RSP(6) Hotpoint 54C/129F 60C/140F
RSP(6) Exhaust
RSP(7) Inlet 44C/111F 50C/122F
RSP(7) Hotpoint 54C/129F 60C/140F
RSP(7) Exhaust
+12 Voltage 10.90 11.61 12.82 13.38
+5 Voltage 4.61 4.94 5.46 5.70
-12 Voltage -10.15 -10.76 -13.25 -13.86
+24 Voltage 20.38 21.51 26.42 27.65
2.5 Reference 2.43 2.51
Shutdown boards at 70C/158F
Shutdown power supplies at 76C/168F
Restart after shutdown below 40C/104F
show version output:
IOS (tm) RSP Software (RSP-JSV-M), Version 12.2(8)T10, RELEASE SOFTWARE (fc1)
Community Member
Re: hardware issue?software issue ?
Hi, Have u recently upgraded any hardware or software in 7513?
If yes, you can do one thing...just power off the router and remove the RAM as well as Flash.Incest it again.And power on the router now.
If you have upgrade the software, might be you need to upgrade bootstrap image in the particular router.
Advice , do it at your own risk.
