Community Member
Has anyone encountered the following problem: .SYS-2-CHUNKBOUNDSIB: Error noticed in the sibling of the chunk EIGRP ExtData, Chunk index : 57
I am encountering this problem on a 7602 running 12.1(5)T7
EIGRP, no MPLS but running ATM
%SYS-2-CHUNKBOUNDSIB: Error noticed in the sibling of the chunk EIGRP ExtData, Chunk index : 57, Chunk real max : 57
-Process= "IP-EIGRP Router", ipl= 0, pid= 132
1 REPLY
Anonymous
N/A
Re: Has anyone encountered the following problem: .SYS-2-CHUNKBO
This is a documented bug of 12.1(5)T named as CSCds42916 "EIGRP crashes TSC after XTAG is bounced then clear ip eigrp n". There is no workaround, so you may try using a different release.
615
