Webcast-Catalyst9k
Having problems with DDR callback between PRI-BRI / Configs included
Hi everyone,
trying to get the remote BRI to dial into the PRI authenticate, hang-up and then PRI should call it back.
Almost there but while the PRI's CLID gets picked up, when the BRI dials in there is no CLID presented (althought the system recognises the number in the show caller output!)
Configs attached: (usernames, passwords and IP addresses omited/scrambled for obvious reasons)
HQ: PRI Config
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname PRI
enable password 7
username WAN password 7
username DATA password 7
memory-size iomem 15
ip subnet-zero
ip name-server . . .
isdn switch-type primary-net5
controller E1 1/0
pri-group timeslots 1-31
interface Ethernet0/0
description connected to xxLAN
ip address xxx
half-duplex
interface Serial1/0:15
description PRI 0000000000
no ip address
encapsulation ppp
dialer pool-member 1
dialer pool-member 2
dialer pool-member 3
dialer pool-member 4
dialer pool-member 5
dialer pool-member 6
dialer pool-member 7
ppp authentication chap
interface Dialer1
description connected to xxxWAN
ip address xxxx
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 1
dialer remote-name xxxWAN
dialer enable-timeout 2
dialer string xxxx
dialer caller xxxxcallback
dialer load-threshold 128 outbound
dialer-group 1
fair-queue
no cdp enable
ppp multilink
interface Dialer2
description connected to xxxDATA
ip address xxx
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 2
dialer remote-name xxxDATA
dialer string 1111
dialer caller 1111callback
dialer-group 1
fair-queue
no cdp enable
ppp multilink
interface Dialer3
description connected to eeeWAN
ip address xxx
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 3
dialer remote-name eeeWAN
dialer string xxx
dialer-group 1
fair-queue
no cdp enable
ppp multilink
interface Dialer4
description connected to gggDATA
ip address xxx
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 4
dialer remote-name gggDATA
dialer string eee
dialer-group 1
fair-queue
no cdp enable
ppp multilink
interface Dialer5
description connected to rrrWAN
ip address ttt
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 5
dialer remote-name rrrWAN
dialer string vvv
dialer-group 1
fair-queue
no cdp enable
ppp multilink
interface Dialer6
description connected to rrrDATA
ip address ggg
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 6
dialer remote-name rrrDATA
dialer string ggg
dialer-group 1
fair-queue
no cdp enable
ppp multilink
interface Dialer7
description connected to home
ip address xxx
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 7
dialer remote-name home
dialer string 00
dialer-group 1
fair-queue
no cdp enable
ppp multilink
ip classless
ip route xxx
ip route yyy Dialer1
ip route zzz Dialer3
ip route ccc Dialer5
ip route vvv Dialer7
ip route bbb Dialer2
ip route nnn Dialer4
ip route mmm Dialer6
ip http server
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
snmp-server community public RO
snmp-server enable traps tty
line con 0
exec-timeout 0 0
password 7 fff
login
line 65 70
flush-at-activation
line aux 0
line vty 0 4
exec-timeout 0 0
password 7
login
end
REMOTE BRI Config
version 12.2
hostname Race
boot host tftp network-confg xxx
enable password 7
username GrovePRI password 7
ip subnet-zero
ip name-server xxx
isdn switch-type basic-net3
interface FastEthernet0/0
description connected to RaceLAN
ip address xxx
duplex auto
speed auto
interface BRI0/0
description eeePRI D1
no ip address
encapsulation ppp
no cdp enable
interface FastEthernet0/1
description connected to eeeData
ip address ccc
duplex auto
speed auto
interface BRI0/1
no ip address
encapsulation ppp
no cdp enable
interface BRI1/0
description eeePRI D2
no ip address
encapsulation ppp
no cdp enable
interface BRI1/1
no ip address
encapsulation ppp
no cdp enable
interface BRI1/2
no ip address
encapsulation ppp
no cdp enable
interface BRI1/3
no ip address
encapsulation ppp
no cdp enable
interface Dialer1
description eeePRI Email
ip address sss
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer idle-timeout 300
dialer redial interval 15 attempts 2
dialer string 2323232323
dialer caller 2323232324
dialer load-threshold 100 either
dialer-group 1
no cdp enable
ppp chap hostname eeeWAN
interface Dialer2
description eeePRI Data
ip address fff
encapsulation ppp
no ip split-horizon
dialer pool 2
dialer string 2121212121
dialer caller 1212121212
dialer-group 2
no cdp enable
ppp chap hostname eeeDATA
ip classless
ip route xxx
ip route ddd
ip route ccc
ip http server
ip pim bidir-enable
snmp-server engineID local snmp-server community public RO
line con 0
exec-timeout 0 0
password 7
login
line aux 0
line vty 0 4
exec-timeout 0 0
password 7
login
end
Re: Having problems with DDR callback between PRI-BRI / Configs
Two things:
1: I am missing the interface command dialer remote-name which links a dialer to it's ISDN peer.
2: When defining a ppp chap hostname, you should also define the password with a second interface command-line:
ppp chap password xxxx
I did not see these line in your config.
Stating the obvious, these username/passwd combinations must be on the opposing router as well in the top of the config:
username data password 1234cisco.
Hope this solves your problem.
Leo
You are trying to configure "isdn callerid callback" so most important part here is the PRI router need to have a callerid received when the call comes in. So if you are not seeing "Calling Party Number" in "debug isdn q931" SETUP message, callback will not work. If callerid is not received, callback will not get authorized.
Here is the link which discuss exactly that along with troubleshooting.
http://www.cisco.com/warp/public/793/access_dial/Isdn_callerID.html
The config looks fine. Only dialer 1 and 2 will initiate callback. So just talk to pri provider so that they forward the callerid when the call comes in to pri lines. Callerid should exactly match in what is received in setup message and in "dialer caller xxxx callback" statement.
Following debug will pin-point the issue, for call come in and callback.
debug isdn q931
debug ppp nego
debug ppp authe
debug aaa authorization
debug dialer
debug ppp cbcp
debug callback
When I do "show caller int d2" in the PRI I can actually see the CLID of the number I am calling (although under dial string it says 0 incoming calls have been screened and 0 incoming calls rejected for callback)
In the "show dialer int d2" on the PRI I can pick up the Dial In number (BRI) but when I do "show isdn a" it does not display a number under the "Calling Number" which I think is what is causing the callback problem.
So we know that the BRI is sending the CLID , the PRI picks it up in some parts but not in the important one...
Any pointers on this?
TIA,
G.
We need to see the debugs that i have posted in the earlier reply to see the issue.
Debugs as promised:
(tel numbers and IP addresses "masked" throughout as previously)
s deb
Dial on demand:
Dial on demand events debugging is on
PPP:
PPP authentication debugging is on
PPP protocol negotiation debugging is on
PPP Callback Control Protocol debugging is on
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON.
debug isdn q931 is ON.
Callback:
Callback activity debugging is on
CustPRI#s isdn a
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
In ---N/A--- 333666 Test2WAN 2458 119 0
In ---N/A--- 333666 Test2DATA 1222 119 0
In ---N/A--- 333666 Test2WAN 1098 119 0
In ---N/A--- 333666 TestWAN 851 119 0
In ---N/A--- 333666 Test2DATA 828 119 0
Out ---N/A--- +123456788 MainWAN 292 119 0 0
Out ---N/A--- +123456787 MainDATA 96 Unavail - 0
CustPRI#sh caller ip
Line User IP Address Local Number Remote Number <->
Se1/0:1 Test2DATA 20.0.0.21 333666 in
Se1/0:2 Test2WAN 20.0.0.17 333666 in
Se1/0:3 Test2WAN 20.0.0.17 333666 in
Se1/0:4 TestWAN 20.0.0.9 333666 in
Se1/0:5 Test2DATA 20.0.0.21 333666 in
Se1/0:28 MainDATA - 1623331113332 out
Di2 MainDATA 20.0.0.5 - - in
CustPRI#
CustPRI#term mon
CustPRI#
2w3d: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xD86F
Cause i = 0x829C - Invalid number format (incomplete number)
2w3d: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x586F
2w3d: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xD86F
2w3d: Serial1/0:15: wait for isdn carrier timeout, call id=0xD872
2w3d: Se1/0:15 DDR: rotor dialout [priority]
2w3d: Se1/0:15 DDR: Dialing cause ip (s=20.0.0.2, d=10.0.10.1)
2w3d: Se1/0:15 DDR: Attempting to dial 1623331113333
2w3d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x5870
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Called Party Number i = 0x81, '1623331113333'
Plan:ISDN, Type:Unknown
2w3d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xD870
Progress Ind i = 0x8288 - In-band info or appropriate now available
2w3d: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD870
2w3d: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xD870
2w3d: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xD870
2w3d: %LINK-3-UPDOWN: Interface Serial1/0:30, changed state to up
2w3d: Se1/0:30: interface must be fifo queue, force fifo
2w3d: %DIALER-6-BIND: Interface Se1/0:30 bound to profile Di1
2w3d: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x5870
2w3d: Se1/0:30 PPP: Treating connection as a callout
2w3d: Se1/0:30 PPP: Phase is ESTABLISHING, Active Open
2w3d: Se1/0:30 PPP: Authorization required
2w3d: Se1/0:30 LCP: O CONFREQ [Closed] id 156 len 30
2w3d: Se1/0:30 LCP: AuthProto CHAP (0x0305C22305)
2w3d: Se1/0:30 LCP: MagicNumber 0x5D0B76BC (0x05065D0B76BC)
2w3d: Se1/0:30 LCP: MRRU 1524 (0x110405F4)
2w3d: Se1/0:30 LCP: EndpointDisc 1 CustPRI (0x130B0147726F7665505249)
2w3d: Se1/0:30 LCP: I CONFREQ [REQsent] id 1 len 15
2w3d: Se1/0:30 LCP: MagicNumber 0x1F0588C6 (0x05061F0588C6)
2w3d: Se1/0:30 LCP: O CONFACK [REQsent] id 1 len 15
2w3d: Se1/0:30 LCP: I CONFREJ [ACKsent] id 156 len 8
2w3d: Se1/0:30 LCP: O CONFREQ [ACKsent] id 157 len 26
2w3d: Se1/0:30 LCP: I CONFACK [ACKsent] id 157 len 26
2w3d: Se1/0:30 LCP: State is Open
2w3d: Se1/0:30 MCB: Initialize
2w3d: Se1/0:30 PPP: Phase is AUTHENTICATING, by both
2w3d: Se1/0:30 CHAP: O CHALLENGE id 101 len 29 from "CustPRI"
2w3d: Se1/0:30 CHAP: I CHALLENGE id 202 len 28 from "MainWAN"
2w3d: Se1/0:30 CHAP: Using hostname from unknown source
2w3d: Se1/0:30 CHAP: Using password from AAA
2w3d: Se1/0:30 CHAP: O RESPONSE id 202 len 29 from "CustPRI"
2w3d: Se1/0:30 CHAP: I SUCCESS id 202 len 4
2w3d: Se1/0:30 CHAP: I RESPONSE id 101 len 28 from "MainWAN"
2w3d: Se1/0:30 PPP: Sent CHAP LOGIN Request to AAA
2w3d: Se1/0:30 PPP: Received LOGIN Response from AAA = PASS
2w3d: Se1/0:30 DDR: Remote name for MainWAN
2w3d: Se1/0:30 CHAP: O SUCCESS id 101 len 4
2w3d: Se1/0:30 PPP: Phase is UP
2w3d: Se1/0:30 IPCP: O CONFREQ [Closed] id 38 len 10
2w3d: Se1/0:30 IPCP: Address 20.0.0.2 (0x03060F000002)
2w3d: Se1/0:30 IPCP: I CONFREQ [REQsent] id 1 len 10
2w3d: Se1/0:30 IPCP: Address 20.0.0.1 (0x03060F000001)
2w3d: Se1/0:30 AAA/AUTHOR/IPCP: Start. Her address 20.0.0.1, we want 0.0.0.0
2w3d: Se1/0:30 AAA/AUTHOR/IPCP: Reject 20.0.0.1, using 0.0.0.0
2w3d: Se1/0:30 AAA/AUTHOR/IPCP: Done. Her address 20.0.0.1, we want 0.0.0.0
2w3d: Se1/0:30 IPCP: O CONFACK [REQsent] id 1 len 10
2w3d: Se1/0:30 IPCP: I CONFACK [ACKsent] id 38 len 10
2w3d: Se1/0:30 IPCP: State is Open
2w3d: Se1/0:30 DDR: dialer protocol up
2w3d: Di1 IPCP: Install route to 20.0.0.1
2w3d: Se1/0:30 IPCP: Add link info for cef entry 20.0.0.1
2w3d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:30, changed state to up
2w3d: %ISDN-6-CONNECT: Interface Serial1/0:30 is now connected to 1623331113333 MainWAN
2w3d: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on Ethernet0/0 (not full duplex), with ADrouter.Factory.WF1 FastEthernet0/1 (full duplex).
2w3d: Se1/0:30 DDR: disconnecting call
2w3d: %ISDN-6-DISCONNECT: Interface Serial1/0:30 disconnected from 1623331113333 MainWAN, call lasted 47 seconds
2w3d: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x5870
Cause i = 0x8090 - Normal call clearing
2w3d: Di1 DDR: No bundle in dialer_fsm_up
2w3d: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xD870
2w3d: %LINK-3-UPDOWN: Interface Serial1/0:30, changed state to down
2w3d: Se1/0:30 IPCP: Remove link info for cef entry 20.0.0.1
2w3d: Se1/0:15 DDR: has total 0 call(s), dial_out 0, dial_in 0
2w3d: %DIALER-6-UNBIND: Interface Se1/0:30 unbound from profile Di1
2w3d: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x5870
2w3d: Di1 IPCP: Remove route to 20.0.0.1
2w3d: Se1/0:30 IPCP: State is Closed
2w3d: Se1/0:30 PPP: Phase is TERMINATING
2w3d: Se1/0:30 LCP: State is Closed
2w3d: Se1/0:30 PPP: Phase is DOWN
2w3d: Se1/0:15 DDR: Dialing cause ip (s=1.0.0.180, d=10.0.10.250)
2w3d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x5871
Standard = CCITT
2w3d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xD871
2w3d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:30, changed state to down
2w3d: Se1/0:28 PPP: Phase is TERMINATING
2w3d: Se1/0:28 LCP: O TERMREQ [Open] id 251 len 4
2w3d: Di2 IPCP: Remove link info for cef entry 20.0.0.5
2w3d: Di2 IPCP: State is Closed
2w3d: Di2 PPP: Phase is TERMINATING
2w3d: Di2 LCP: State is Closed
2w3d: Di2 PPP: Phase is DOWN
2w3d: Di2 DDR: disconnecting call
2w3d: Di2 DDR is disconnecting, could not clear interface.
2w3d: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD871
2w3d: Di2 IPCP: Remove route to 20.0.0.5
2w3d: Se1/0:28 LCP: I TERMACK [TERMsent] id 251 len 4
2w3d: Se1/0:28 LCP: State is Closed
2w3d: Se1/0:28 PPP: Phase is DOWN
2w3d: Se1/0:28 DDR: disconnecting call
2w3d: Se1/0:28 PPP: Phase is ESTABLISHING, Passive Open
2w3d: Se1/0:28 LCP: State is Listen
2w3d: %ISDN-6-DISCONNECT: Interface Serial1/0:28 disconnected from 1623331113332 MainDATA, call lasted 189 seconds
2w3d: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x586A
2w3d: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xD86A
2w3d: %LINK-3-UPDOWN: Interface Serial1/0:28, changed state to down
2w3d: %DIALER-6-UNBIND: Interface Se1/0:28 unbound from profile Di2
2w3d: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x586A
2w3d: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xD871
2w3d: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xD871
2w3d: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x5871
2w3d: Se1/0:30 LCP: O CONFREQ [Closed] id 158 len 30
2w3d: Se1/0:30 LCP: MagicNumber 0x5D0C3981 (0x05065D0C3981)
2w3d: Se1/0:30 LCP: MagicNumber 0x1F064B87 (0x05061F064B87)
2w3d: Se1/0:30 LCP: I CONFREJ [ACKsent] id 158 len 8
2w3d: Se1/0:30 LCP: O CONFREQ [ACKsent] id 159 len 26
2w3d: Se1/0:30 LCP: I CONFACK [ACKsent] id 159 len 26
2w3d: Se1/0:30 CHAP: O CHALLENGE id 102 len 29 from "CustPRI"
2w3d: Se1/0:30 CHAP: I CHALLENGE id 203 len 28 from "MainWAN"
2w3d: Se1/0:30 CHAP: O RESPONSE id 203 len 29 from "CustPRI"
2w3d: Se1/0:30 CHAP: I SUCCESS id 203 len 4
2w3d: Se1/0:30 CHAP: I RESPONSE id 102 len 28 from "MainWAN"
2w3d: Se1/0:30 CHAP: O SUCCESS id 102 len 4
2w3d: Se1/0:30 IPCP: O CONFREQ [Closed] id 39 len 10
2w3d: Se1/0:30 IPCP: I CONFACK [ACKsent] id 39 len 10
2w3d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:28, changed state to down
2w3d: Se1/0:15 DDR: Dialing cause ip (s=20.0.0.6, d=20.0.0.6)
2w3d: Se1/0:15 DDR: Attempting to dial 1623331113332
2w3d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x5872
Standard = CCITT
Channel ID i = 0xA9839E
Exclusive, Channel 30
Called Party Number i = 0x81, '1623331113332'
2w3d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xD872
2w3d: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD872
2w3d: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xD872
2w3d: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xD872
2w3d: %LINK-3-UPDOWN: Interface Serial1/0:29, changed state to up
2w3d: Se1/0:29: interface must be fifo queue, force fifo
2w3d: %DIALER-6-BIND: Interface Se1/0:29 bound to profile Di2
2w3d: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x5872
2w3d: Se1/0:29 PPP: Treating connection as a callout
2w3d: Se1/0:29 PPP: Phase is ESTABLISHING, Active Open
2w3d: Se1/0:29 PPP: Authorization required
2w3d: Se1/0:29 LCP: O CONFREQ [Closed] id 150 len 30
2w3d: Se1/0:29 LCP: AuthProto CHAP (0x0305C22305)
2w3d: Se1/0:29 LCP: MagicNumber 0x5D0C6843 (0x05065D0C6843)
2w3d: Se1/0:29 LCP: MRRU 1524 (0x110405F4)
2w3d: Se1/0:29 LCP: EndpointDisc 1 CustPRI (0x130B0147726F7665505249)
2w3d: Se1/0:29 LCP: I CONFREQ [REQsent] id 1 len 30
2w3d: Se1/0:29 LCP: MagicNumber 0x1F067A4D (0x05061F067A4D)
2w3d: Se1/0:29 LCP: EndpointDisc 1 MainDATA (0x130B015261636544415441)
2w3d: Se1/0:29 LCP: O CONFACK [REQsent] id 1 len 30
2w3d: Se1/0:29 LCP: I CONFACK [ACKsent] id 150 len 30
2w3d: Se1/0:29 LCP: State is Open
2w3d: Se1/0:29 MCB: Initialize
2w3d: Se1/0:29 PPP: Phase is AUTHENTICATING, by both
2w3d: Se1/0:29 CHAP: O CHALLENGE id 34 len 29 from "CustPRI"
2w3d: Se1/0:29 CHAP: I CHALLENGE id 18 len 29 from "MainDATA"
2w3d: Se1/0:29 CHAP: Using hostname from unknown source
2w3d: Se1/0:29 CHAP: Using password from AAA
2w3d: Se1/0:29 CHAP: O RESPONSE id 18 len 29 from "CustPRI"
2w3d: Se1/0:29 CHAP: I SUCCESS id 18 len 4
2w3d: Se1/0:29 CHAP: I RESPONSE id 34 len 29 from "MainDATA"
2w3d: Se1/0:29 PPP: Sent CHAP LOGIN Request to AAA
2w3d: Se1/0:29 PPP: Received LOGIN Response from AAA = PASS
2w3d: Se1/0:29 DDR: Remote name for MainDATA
2w3d: Se1/0:29 CHAP: O SUCCESS id 34 len 4
2w3d: Se1/0:29 PPP: Phase is VIRTUALIZED
2w3d: Di2 MLP: Added first link Se1/0:29 to bundle MainDATA
2w3d: Di2 PPP: Treating connection as a callout
2w3d: Di2 PPP: Phase is UP
2w3d: Di2 IPCP: O CONFREQ [Closed] id 154 len 10
2w3d: Di2 IPCP: Address 20.0.0.6 (0x03060F000006)
2w3d: Di2 IPCP: I CONFREQ [REQsent] id 73 len 10
2w3d: Di2 IPCP: Address 20.0.0.5 (0x03060F000005)
2w3d: Di2 AAA/AUTHOR/IPCP: Start. Her address 20.0.0.5, we want 0.0.0.0
2w3d: Di2 AAA/AUTHOR/IPCP: Reject 20.0.0.5, using 0.0.0.0
2w3d: Di2 AAA/AUTHOR/IPCP: Done. Her address 20.0.0.5, we want 0.0.0.0
2w3d: Di2 IPCP: O CONFACK [REQsent] id 73 len 10
2w3d: Di2 IPCP: I CONFACK [ACKsent] id 154 len 10
2w3d: Di2 IPCP: State is Open
2w3d: Di2 DDR: dialer protocol up
2w3d: Di2 IPCP: Install route to 20.0.0.5
2w3d: Di2 IPCP: Add link info for cef entry 20.0.0.5
2w3d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:29, changed state to up
2w3d: %ISDN-6-CONNECT: Interface Serial1/0:29 is now connected to 1623331113332 MainDATA
2w3d: %ISDN-6-DISCONNECT: Interface Serial1/0:30 disconnected from 1623331113333 MainWAN, call lasted 18 seconds
2w3d: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x5871
2w3d: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xD871
2w3d: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x5871
2w3d: Se1/0:29 PPP: Phase is TERMINATING
2w3d: Se1/0:29 LCP: O TERMREQ [Open] id 151 len 4
2w3d: Se1/0:29 LCP: I TERMACK [TERMsent] id 151 len 4
2w3d: Se1/0:29 LCP: State is Closed
2w3d: Se1/0:29 PPP: Phase is DOWN
2w3d: Se1/0:29 DDR: disconnecting call
2w3d: Se1/0:29 PPP: Phase is ESTABLISHING, Passive Open
2w3d: Se1/0:29 LCP: State is Listen
2w3d: %ISDN-6-DISCONNECT: Interface Serial1/0:29 disconnected from 1623331113332 MainDATA, call lasted 10 seconds
2w3d: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x5872
2w3d: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xD872
2w3d: %LINK-3-UPDOWN: Interface Serial1/0:29, changed state to down
2w3d: %DIALER-6-UNBIND: Interface Se1/0:29 unbound from profile Di2
2w3d: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x5872
2w3d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:29, changed state to down
2w3d: Se1/0:15 DDR: Dialing cause ip (s=20.0.0.2, d=20.0.0.2)
2w3d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x5873
Standard = CCITT
2w3d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xD873
2w3d: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD873
2w3d: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xD873
2w3d: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xD873
2w3d: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x5873
2w3d: Se1/0:30 LCP: O CONFREQ [Closed] id 160 len 30
2w3d: Se1/0:30 LCP: MagicNumber 0x5D0CA288 (0x05065D0CA288)
2w3d: Se1/0:30 LCP: MagicNumber 0x1F06B492 (0x05061F06B492)
2w3d: Se1/0:30 LCP: I CONFREJ [ACKsent] id 160 len 8
2w3d: Se1/0:30 LCP: O CONFREQ [ACKsent] id 161 len 26
2w3d: Se1/0:30 LCP: I CONFACK [ACKsent] id 161 len 26
2w3d: Se1/0:30 CHAP: O CHALLENGE id 103 len 29 from "CustPRI"
2w3d: Se1/0:30 CHAP: I CHALLENGE id 204 len 28 from "MainWAN"
2w3d: Se1/0:30 CHAP: O RESPONSE id 204 len 29 from "CustPRI"
2w3d: Se1/0:30 CHAP: I SUCCESS id 204 len 4
2w3d: Se1/0:30 CHAP: I RESPONSE id 103 len 28 from "MainWAN"
2w3d: Se1/0:30 CHAP: O SUCCESS id 103 len 4
2w3d: Se1/0:30 IPCP: O CONFREQ [Closed] id 40 len 10
2w3d: Se1/0:30 IPCP: I CONFACK [ACKsent] id 40 len 10
2w3d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x5874
Standard = CCITT
2w3d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xD874
2w3d: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD874
2w3d: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xD874
2w3d: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xD874
2w3d: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x5874
2w3d: Se1/0:29 LCP: O CONFREQ [Closed] id 152 len 30
2w3d: Se1/0:29 LCP: MagicNumber 0x5D0CB296 (0x05065D0CB296)
2w3d: Se1/0:29 LCP: MagicNumber 0x1F06C4A0 (0x05061F06C4A0)
2w3d: Se1/0:29 LCP: I CONFACK [ACKsent] id 152 len 30
2w3d: Se1/0:29 CHAP: O CHALLENGE id 35 len 29 from "CustPRI"
2w3d: Se1/0:29 CHAP: I CHALLENGE id 19 len 29 from "MainDATA"
2w3d: Se1/0:29 CHAP: O RESPONSE id 19 len 29 from "CustPRI"
2w3d: Se1/0:29 CHAP: I SUCCESS id 19 len 4
2w3d: Se1/0:29 CHAP: I RESPONSE id 35 len 29 from "MainDATA"
2w3d: Se1/0:29 CHAP: O SUCCESS id 35 len 4
2w3d: Di2 IPCP: O CONFREQ [Closed] id 155 len 10
2w3d: Di2 IPCP: I CONFREQ [REQsent] id 74 len 10
2w3d: Di2 IPCP: O CONFACK [REQsent] id 74 len 10
2w3d: Di2 IPCP: I CONFACK [ACKsent] id 155 len 10
2w3d: %ISDN-6-DISCONNECT: Interface Serial1/0:30 disconnected from 1623331113333 MainWAN, call lasted 29 seconds
2w3d: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x5873
2w3d: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xD873
2w3d: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x5873
2w3d: Se1/0:29 LCP: O TERMREQ [Open] id 153 len 4
2w3d: Se1/0:29 LCP: I TERMACK [TERMsent] id 153 len 4
2w3d: %ISDN-6-DISCONNECT: Interface Serial1/0:29 disconnected from 1623331113332 MainDATA, call lasted 27 seconds
2w3d: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x5874
2w3d: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xD874
2w3d: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x5874
2w3d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x5875
Standard = CCITT
2w3d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xD875
2w3d: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD875
2w3d: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xD875
2w3d: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xD875
2w3d: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x5875
2w3d: Se1/0:30 LCP: O CONFREQ [Closed] id 162 len 30
2w3d: Se1/0:30 LCP: MagicNumber 0x5D0D2BB3 (0x05065D0D2BB3)
2w3d: Se1/0:30 LCP: MagicNumber 0x1F073DBD (0x05061F073DBD)
2w3d: Se1/0:30 LCP: I CONFREJ [ACKsent] id 162 len 8
2w3d: Se1/0:30 LCP: O CONFREQ [ACKsent] id 163 len 26
2w3d: Se1/0:30 LCP: I CONFACK [ACKsent] id 163 len 26
2w3d: Se1/0:30 CHAP: O CHALLENGE id 104 len 29 from "CustPRI"
2w3d: Se1/0:30 CHAP: I CHALLENGE id 205 len 28 from "MainWAN"
2w3d: Se1/0:30 CHAP: O RESPONSE id 205 len 29 from "CustPRI"
2w3d: Se1/0:30 CHAP: I SUCCESS id 205 len 4
2w3d: Se1/0:30 CHAP: I RESPONSE id 104 len 28 from "MainWAN"
2w3d: Se1/0:30 CHAP: O SUCCESS id 104 len 4
2w3d: Se1/0:30 IPCP: O CONFREQ [Closed] id 41 len 10
2w3d: Se1/0:30 IPCP: I CONFACK [ACKsent] id 41 len 10
2w3d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x5876
Standard = CCITT
2w3d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xD876
2w3d: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD876
2w3d: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xD876
2w3d: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xD876
2w3d: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x5876
2w3d: Se1/0:29 LCP: O CONFREQ [Closed] id 154 len 30
2w3d: Se1/0:29 LCP: MagicNumber 0x5D0D3C65 (0x05065D0D3C65)
2w3d: Se1/0:29 LCP: MagicNumber 0x1F074E6B (0x05061F074E6B)
2w3d: Se1/0:29 LCP: I CONFACK [ACKsent] id 154 len 30
2w3d: Se1/0:29 CHAP: O CHALLENGE id 36 len 29 from "CustPRI"
2w3d: Se1/0:29 CHAP: I CHALLENGE id 20 len 29 from "MainDATA"
2w3d: Se1/0:29 CHAP: O RESPONSE id 20 len 29 from "CustPRI"
2w3d: Se1/0:29 CHAP: I SUCCESS id 20 len 4
2w3d: Se1/0:29 CHAP: I RESPONSE id 36 len 29 from "MainDATA"
2w3d: Se1/0:29 CHAP: O SUCCESS id 36 len 4
2w3d: Di2 IPCP: O CONFREQ [Closed] id 156 len 10
2w3d: Di2 IPCP: I CONFREQ [REQsent] id 75 len 10
2w3d: Di2 IPCP: O CONFACK [REQsent] id 75 len 10
2w3d: Di2 IPCP: I CONFACK [ACKsent] id 156 len 10
All those debugs are from PRI router which should receive the call from bri router and callback right?
I am not seeing any calls received ON PRI router, all the calls are originated FROM PRI router. So callback will not be negotiated during LCP.
Now as per the config of BRI router, the "ppp callback request" is missing under the dialer interface so with that included in the config, BRI router will dialin to PRI router and negotiate callback and drop the line & after that PRI router will callback.
Yes, all the debugs are from the PRI.
Will try the callback request today but this still doesnt answer my query about being able to see the "called" call but not the "calling" number as per previous post...
218
