having trouble starting nGenius 1.4
I am trying to install RTM 1.4 on a dedicated Win2K SP2. During the install, an error message occurs "cannot create secured user". Nonetheless, a user ngenius is created. But the nGenius service cannot start due to a "logon failure - invalid logon type for a user" according to Windows event viewer. Yet, I can login with the ngenius user OK.
Has anybody run across this problem?
Thanks.
1 REPLY
Blue
Re: having trouble starting nGenius 1.4
Refer to the section "Q. Why wasn't a secured user created when I installed RTM 1.4 on a Windows system?" at:
http://www.cisco.com/warp/public/477/RTM/rtm_faq.shtml#secure for the details.
75
