HELP!2611XM Cann't boot up
I erased the flash when I upgrade the IOS,Then Boot up the router,it have a error message (boot: cannot open 'flash"),but I cann't enter the Rommon mode.
How can I do?
Thanks!
Re: HELP!2611XM Cann't boot up
You would have to make sure that you are sending the correct break signal with your terminal (emulation) can you break on another router ?
Yes,I sure
the problem maybe NVRam.Is there have any methode to erase or rebuild the data on NVRam?
95
