Help 7206 FastEthernet port trouble
HI
There is a 7206 router FastEthernet port connect a IBM PC .now the trouble is sometime the connection between 7206 and IBM PC has break,but show the port state it is up.
After reset the FastEthernet port,the connection is rejuvenate.but the trouble will happen again in unknowable time.maybe two days or two weeks.
I had change the router engine module,however the problem is happen again.
Any help would be greatly appreciated.
1 REPLY
Re: Help 7206 FastEthernet port trouble
What version of code are you running? You may be running into bug CSCds72867.
On a Cisco 7200 series router-I/O-2FE/E io-controller or PA-2FE-TX or PA-2FE-FX port adapter, the interface may stop receiving under extreme loads. There is no workaround.
Bug found in: 12.1T 12.0S 12.1E
Fixed in: 12.0(14)ST 12.0(14.1)S 12.1(4.4)E 12.1(5.3)T 12.0(14)S01 12.1(4.4)EC 12.0(14.3)ST 12.0(14.6)SC
99
