HELP!!! Can WS-X5403 be used in Catalyst5513 ?
The show version of Catalyst5513 is as following:
WS-C5500 Software, Version McpSW: 5.5(16) NmpSW: 5.5(16)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Aug 6 2002, 15:08:36
MCP S/W compiled on Aug 06 2002, 15:11:31
System Bootstrap Version: 5.1(2)
Hardware Version: 1.4 Model: WS-C5500 Serial #: 069081454
Mod Port Model Serial # Versions
1 2 WS-X5509 013511697 Hw : 2.8
Fw : 5.1(2)
Fw1: 4.3(1)
Sw : 5.5(16)
WS-F5511 013506030 Hw : 1.1
3 24 WS-X5225R 014382307 Hw : 3.3
Fw : 4.3(1)
Sw : 5.5(16)
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 32768K 15242K 17526K 8192K 7168K 1024K 256K 185K 71K
Uptime is 0 day, 0 hour, 28 minutes
Bronze
Re: HELP!!! Can WS-X5403 be used in Catalyst5513 ?
The WS-X5403 should work in the Cat 5513. Here is a URL that has information for the WS-X5403 http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/hardware/modules/04ether.htm#23384
Bronze
should be.
Release notes for 5.5.x for the cat5k don't say otherwise. The card is first supported in 4.1(1)
Link to the release notes ( Look under the hardware/software matrix )
URL: http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/c5krn/sw_rns/78_6583.htm
89
