Help Cat6506 Crash
Hi I was wondering if anyone out there working with the Cat6506's ever received this error message on a crash.
*** Emulating mis-aligned store at 0x00040082
PC = 0xbfc03ea0 ...
*** TLB (Store) Exception ***
Access address = 0x40082
PC = 0xbfc09508, Cause = 0xc80c, Status Reg = 0x24410003
Any help would be great!!! Cisco can't seem to resolve the issue. 5 Sups and a Chassis replacement I still have the same issue.
Can someone help?
NOTE:
I have no access to the MSFC. That's managed by our ISP.
Blue
Re: Help Cat6506 Crash
when replacing the supervisors, did the memory get replaced or just swapped from the old to the new? seems like a problem storing data in the memory.....
as with TAC, i cannot find a specific document describing this issue.
if all else fails and you really need to get this resolved, tell TAC to escalate the case and provide a 'Root Cause Analysis'. this usually takes awhile, a few weeks to a couple of months is my experience. (they usually need to duplicate the symptom for starters)
Thanks for the reply. I have changed the memory out twice with new memory. I'm not sure what else the problem could be. This is really frustrating. I have searched all over the web for this issue and I can not find anything on it.
I will keep on looking. The switch seems to crash like once a month. :o(
132
