Community Member
Help changing password on cisco 1700 router
Any help on changing the password from one to another would be helpful thanks
Bronze
Re: Help changing password on cisco 1700 router
Follow the instructions on this link to recover your password. You will have to be consoled into the router to enter the break sequence.
http://www.cisco.com/warp/public/474/pswdrec_1700.shtml
Community Member
Raymong i know the current password i just want to change it ?
Bronze
Sorry... if you want to change the enable password:
Router#config t
Router(config)#enable secret
or
Router(config)#enable password
If you're trying to change the telnet password:
Router#config t
Router(config)#line vty 0 4
Router(config-line)#password
116
