Webcast-Catalyst9k
Help config Cisco 2620/Asynchronous modem card NM-16AM
I purchased Cisco 2620 recently router with Asynchronous modem card (NM-16AM) included, my goal is to drive incoming call from Terminal using modem and drive it to server IP addressee in 6666 port without any authentification under Clear TCP (my soft communication use server IP address and 6666 port), I need to know if it possible to configure my Router to do this and if someone know a link in Cisco site where I can find a configuration sample.
Thanks in advance
1 REPLY
Bronze
Re: Help config Cisco 2620/Asynchronous modem card NM-16AM
Yes. I couldn't really find a configuration example but this is what you will want to configure. You will just change the server IP address.
This configuration will accept dialup connections and once connected automatically open a TCP connection to your server on port 6666.
interface ethernet 0
ip address 10.1.1.254 255.0.0.0
ip host SERVER 6666 10.1.1.1
line 1 16
modem inout
flowcontrol hardware
transport input all
autocommand telnet SERVER
no login
Let me know if this helps.
Daniel
135
