Community Member
Help!!! Content engine
my configuration is follow the attached file. I don't know what is wrong with my content engine using as a cache server. when i connect this CE to my network, i can make my user access to the internet fast only 2 days, but after 2 days it makes my users internet connection slow. So when users access to the internet slow, i disconnect this CE from my network, then my users internet connections is running better. So please help me to find what is incorrect with my configuration and what commands i should add more to this current configuration"
Re: Help!!! Content engine
What is the ACNS software version u r using in ur content Engine7305.I am sending u a configuration doc for ACNS rlease 5.2.This has all the info regarding ACNS 5.2.
Let me know, if you have any problem in browsing this big document. and finding out the pblm.I will assist you.
Community Member
We are currently having the same problem. Did you find a solution to your problem? We are running 525's version 5.3.5
