Community Member
Help!!! - Erase Flash error! 3750 Catalyst Switch
In my error I ran a 'erase flash' and deleted the entire flash rather than a file within the flash. Now the switch boots into a 'switch:' mode with limited options. Is there a way of copying across a flash. Xmodem doesnt seem an option?
Re: Help!!! - Erase Flash error! 3750 Catalyst Switch
Please try if the following applies to your switch:
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a0080110ed1.shtml#hw
Leo
Community Member
Replied by: slisney - Nov 14, 2005, 4:20am PST
The contents below are the only commands when I type ?, I have a load_helper but it doesnt seem to help. I was hoping to do a rommon, then download the file from hypertrm but it doesnt seem to work? any other ideas, thanks
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
sleep -- Pause (sleep) for a specified number of seconds
-- MORE --
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
switch:
Community Member
-- MORE --
switch:
VIP Purple
can you try the 'flash_init' command first ?
Have a look at the document below (it is not specifically for the 3750, but I think the procedure is the same):
Recovering Catalyst 2950, 2955, and 3550 Series Switches from a Corrupted or Missing Image
http://www.cisco.com/warp/public/473/192.html
HTH,
GP
In additions to leos comments would like to know the issues in using the Xmodem option available out there.
i have seen uploading ios using Xmodem into the 3750 switches only the .bin files ,if possible can u also try that and chck it up how it goes..
once u r thru with that you mite want to check this link to get on the whole bundle onto ur flash system..
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00805023db.html
regds
Community Member
Thanks, it worked!!!! - I used the copy xmodem command and it took around 2 hours to copy the file. Then used the boot flash:(file name) and it works all ok. cheers
1027
