Community Member
Help for an intersting solution
I want to enable UDP packets, which consist of trading datas genarating from one server in a different network and allow this data to reach enduser at their home.We are having an existing setup of Cable ISP with uBR 7223.
I was trying to route the needed packets using Cisco uBR 924 to the ISP network.But not having good idea of what to do at the uBR 7223 so that those using internet are not allowed to get this broadcast.Is it good using the same setup . Or should look for another CMTS and setups.
Jayaraj
1 REPLY
Bronze
Re: Help for an intersting solution
If you want this data private over the Internet you’ll have to setup VPN or something.
166
