Help!! Have 2 chassis AS5300 (one more older than other) (+ inside )
More older unit can't define two modules with MICA modems (240 mdms in a whole). More newer unit define them without problems.
But both units define a module with 8 E1 ports.
What can be a problem? I have "sh tech" output in a files for both units and can send it to an expert who will try to help me.
Azamat
ExNet ISP
info@exnet.kg
Silver
Re: Help!! Have 2 chassis AS5300 (one more older than other) (+
When you say older unit do you mean older IOS? The carrier card for the 12 port modem module is AS53-CC2-DM...This can be used for both the 6 & 12 port modules. Ensure you have the CC2 card.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/5300/hw_inst/mod_inst/53mmicv2.htm
Thanks, Mak.
Mak
only with AS53-CC2-DM we can put 240 MICA modems to the case.
one unit is manuf. 1999 and the second at 2000
Also I have following message during "sh tech" at "old" unit:
ROM: System Bootstrap, Version 11.2(9)XA, RELEASE SOFTWARE (fc2)
at more newer one this message looks like this:
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
but at one cisco document I saw that double density modem card will work with boot code ver. 12 and late.
is this difference causes a problem with identification of installed cards in older unit?
You are right..you need to have a boot code 12.0(2)XA, 12.0(3)T, 12.1(1), 12.1(1)T, 12.1(5)T or later in oder to get AS53-CC2-DM recognized in the system.
Following is the url which discuss exactly the same. visit table 2.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/5300/sw_conf/sw_ports/compmat/53ios6pt.htm
So upgrading the bootcode will resolve the issue.
Thank you for yor response
Pls say where can I get a step-by-step explanation of upgrading procedure?
I have to replace a ROM chip from my chassis to one with new verion ?
or old version of boot code from my ROM-chip can be replaced by the new one without changing a chip itself? who can do it? I have to ask the nearest Cisco partner?
76
