Community Member
help : how to configure for receiving the remote connection.
I would like to setting router ( cisco2511 ) to receive the connection from remote access. i've setup the remote side by "dialup networking" and connect via modem telephone line to the router. when connected and verify username/password, then disconnect. the dialup networking screen display "remote server can't estrablish connection" or something like that.
i use login local ( security authenticate by the router ), not use radius server.
please help me how to got the right config.
The config.
Cisco2511#show run
Building configuration...
Current configuration:
version 11.3
service timestamps debug uptime
service timestamps log uptime
hostname Cisco2511
aaa new-model
aaa authentication login default local
aaa authentication ppp default if-needed local
aaa authorization network default if-authenticated local
enable secret xxxxx
enable password xxxx
username xxxx
username xxxx
interface Ethernet0
ip address
interface Serial0
no ip address
interface Serial1
no ip address
interface Group-Async1
ip unnumbered Ethernet0
encapsulation ppp
ip tcp header-compression passive
async mode dedicated
peer default ip address pool setup_pool
ppp authentication chap pap
group-range 1 16
router igrp 1
redistribute connected
ip local pool setup_pool
ip classless
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
snmp-server community public RO
line con 0
line 1 16
exec-timeout 0 0
autoselect during-login
autoselect ppp
modem Dialin
transport input all
stopbits 1
speed 38400
flowcontrol hardware
line aux 0
line vty 0 4
password msmengman
And here is debug when recieving connection from remote access.
07:53:28: TTY6: DSR came up
07:53:28: tty6: Modem: IDLE->READY
07:53:30: %LINK-3-UPDOWN: Interface Async6, changed state to up
07:53:30: As6 PPP: Treating connection as a dedicated line
07:53:30: As6 PPP: Phase is ESTABLISHING, Active Open
07:53:30: As6 LCP: O CONFREQ [Closed] id 23 len 25
07:53:30: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:30: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:30: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:30: As6 LCP: PFC (0x0702)
07:53:30: As6 LCP: ACFC (0x0802)
07:53:33: As6 LCP: TIMEout: Time 0x1B1895C State REQsent
07:53:33: As6 LCP: O CONFREQ [REQsent] id 24 len 25
07:53:33: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:33: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:33: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:33: As6 LCP: PFC (0x0702)
07:53:33: As6 LCP: ACFC (0x0802)
07:53:35: As6 LCP: TIMEout: Time 0x1B194FC State REQsent
07:53:35: As6 LCP: O CONFREQ [REQsent] id 25 len 25
07:53:35: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:35: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:35: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:35: As6 LCP: PFC (0x0702)
07:53:35: As6 LCP: ACFC (0x0802)
07:53:37: As6 LCP: TIMEout: Time 0x1B19CEC State REQsent
07:53:37: As6 LCP: O CONFREQ [REQsent] id 26 len 25
07:53:37: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:37: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:37: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:37: As6 LCP: PFC (0x0702)
07:53:37: As6 LCP: ACFC (0x0802)
07:53:39: As6 LCP: TIMEout: Time 0x1B1A4DC State REQsent
07:53:39: As6 LCP: O CONFREQ [REQsent] id 27 len 25
07:53:39: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:39: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:39: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:39: As6 LCP: PFC (0x0702)
07:53:39: As6 LCP: ACFC (0x0802)
07:53:41: As6 LCP: TIMEout: Time 0x1B1ACCC State REQsent
07:53:41: As6 LCP: O CONFREQ [REQsent] id 28 len 25
07:53:41: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:41: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:41: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:41: As6 LCP: PFC (0x0702)
07:53:41: As6 LCP: ACFC (0x0802)
07:53:43: As6 LCP: TIMEout: Time 0x1B1B4BC State REQsent
07:53:43: As6 LCP: O CONFREQ [REQsent] id 29 len 25
07:53:43: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:43: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:43: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:43: As6 LCP: PFC (0x0702)
07:53:43: As6 LCP: ACFC (0x0802)
07:53:45: As6 LCP: TIMEout: Time 0x1B1BCAC State REQsent
07:53:45: As6 LCP: O CONFREQ [REQsent] id 30 len 25
07:53:45: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:45: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:45: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:45: As6 LCP: PFC (0x0702)
07:53:45: As6 LCP: ACFC (0x0802)
07:53:47: As6 LCP: TIMEout: Time 0x1B1C49C State REQsent
07:53:47: As6 LCP: O CONFREQ [REQsent] id 31 len 25
07:53:47: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:47: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:47: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:47: As6 LCP: PFC (0x0702)
07:53:47: As6 LCP: ACFC (0x0802)
07:53:49: As6 LCP: TIMEout: Time 0x1B1CCA0 State REQsent
07:53:49: As6 LCP: O CONFREQ [REQsent] id 32 len 25
07:53:49: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:49: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:49: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:49: As6 LCP: PFC (0x0702)
07:53:49: As6 LCP: ACFC (0x0802)
07:53:51: As6 LCP: TIMEout: Time 0x1B1D494 State REQsent
07:53:51: As6 LCP: O CONFREQ [REQsent] id 33 len 25
07:53:51: As6 LCP: ACCM 0x000A0000 (0x0206000A0000)
07:53:51: As6 LCP: AuthProto CHAP (0x0305C22305)
07:53:51: As6 LCP: MagicNumber 0xE1CFDF8C (0x0506E1CFDF8C)
07:53:51: As6 LCP: PFC (0x0702)
07:53:51: As6 LCP: ACFC (0x0802)
07:53:53: As6 LCP: TIMEout: Time 0x1B1DC84 State REQsent
07:53:53: TTY6: Async Int reset: Dropping DTR
07:53:53: As6 LCP: State is Listen
07:53:54: TTY6: DSR was dropped
07:53:54: tty6: Modem: READY->HANGUP
07:53:55: %LINK-5-CHANGED: Interface Async6, changed state to reset
07:53:55: As6 LCP: State is Closed
07:53:55: As6 PPP: Phase is DOWN
07:53:55: TTY6: dropping DTR, hanging up
07:53:55: tty6: Modem: HANGUP->IDLE
07:53:56: TTY6: cleanup pending. Delaying DTR
07:53:57: TTY6: cleanup pending. Delaying DTR
07:53:58: Async6: allowing modem_process to continue hangup
07:54:00: %LINK-3-UPDOWN: Interface Async6, changed state to down
07:54:00: As6 LCP: State is Closed
07:54:00: As6 PPP: Phase is DOWN
07:54:00: TTY6: restoring DTR
Re: help : how to configure for receiving the remote connection.
From the debugs we see that we start LCP & send out LCPREQ but do not see any response come in.
What external modem do you have? Try removing the speed command from under the lines. If the dialin is a PC we can capture PPP logs on the PC to see if the PC receives the LCPREQ from the router or not & whether it is sending a response to it (but the router does not see it maybe coz the packet is getting corrupted or dropping on the way)
