Help in design
Hi all
We are in a plan to design a N/W using fibre between 2 places.ones the isp end and the second one the customer end.B/W will be morethan 8Mbps so we are going for fibre connectivity between both the places.
Placing MUX at both ends the Output from the mux will be an Ethernet which in turn will be connecting to a switch.i need all u r suggestions to proceed further taking all the factors(security,B/W control,redundancy components to use at both the ends ,N/W design etc.,,)
thks in advance
prm
1 REPLY
Re: Help in design
which MUX are you trying to use, because I dont think all MUXes support ethernet connectivity.
You are going to terminate the connectivity on a switch ?? does that support L3 capability ??
we can talk about all the factors..
mail me at rajagopal_s@lycos.com
Cheers
80
