Help in switch port analysis
Greetings!
I am new to Switch monitoring. I have setup span in a 2900 cisco switch. The actual command i used is: "set span 2/1 3/25". But it is not giving the full traffic. Am i missing out anything?
Thanks and Regards,
Saifullah
1 REPLY
VIP Purple
Re: Help in switch port analysis
try this:
Switch> (enable) set span 2/1 3/25 both
Switch> (enable) set span enable
Although 'both' is the default when nothing is specified, check if explicitly stating it gives your more traffic to monitor.
GP
80
