HELP-Initating ISDN backup from a AS5300
jpelletier
I need help here...I need to initaite the backup from a AS5300 to a remote 2600 series router. How can this be accomplished? Help if you can-thanks
tepatel
First we need to decide the primary line and backup line. So on the event of primary line failure you can activate the secondary line.
Here are some of the sample config links where you will be able to design and configure the backup schemes.
http://www.cisco.com/warp/public/471/backup_cookbook.html
Hope this helps..Thx..Tejal
