Community Member
help,is it a protocol problem?
1142: *Apr 2 10:51:12: %SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking GigabitEthernet0/1 on VLAN0202. Port consistency restored.
2006 Apr 20 17:28:39 utc +08:00 %SPANTREE-2-PORTUNBLK: Unblock previously inc port 3/1 on VLAN 202
2006 Apr 20 17:28:39 utc +08:00 %SPANTREE-2-PORTUNBLK: Unblock previously inc port 3/1 on VLAN 114
51: Inconsistent local vlan.
50: *Mar 1 00:36:34: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking GigabitEthernet0/2 on vlan 114.
49: Inconsistent peer vlan.
48: *Mar 1 00:36:34: %SPANTREE-2-BLOCK_PVID_PEER: Blocking GigabitEthernet0/2 on vlan 202.
47: Received BPDU with inconsistent peer vlan id 202 on GigabitEthernet0/2 on vlan 114.
46: *Mar 1 00:36:34: %SPANTREE-2-RECV_PVID_ERR:
430: Inconsistent local vlan.
429: *Mar 1 06:54:08: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking GigabitEthernet0/1 on vlan 114.
428: Inconsistent peer vlan.
427: *Mar 1 06:54:08: %SPANTREE-2-BLOCK_PVID_PEER: Blocking GigabitEthernet0/1 on vlan 202.
426: Received BPDU with inconsistent peer vlan id 202 on GigabitEthernet0/1 on vlan 114.
425: *Mar 1 06:54:08: %SPANTREE-2-RECV_PVID_ERR:
1141: *Apr 2 10:50:57: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking GigabitEthernet0/1 on VLAN0114. Inconsistent local vlan.
1140: *Apr 2 10:50:57: %SPANTREE-2-BLOCK_PVID_PEER: Blocking GigabitEthernet0/1 on VLAN0202. Inconsistent peer vlan.
1139: *Apr 2 10:50:57: %SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan id 202 on GigabitEthernet0/1 VLAN114.
2006 Apr 20 17:28:25 utc +08:00 %SPANTREE-2-TX_BLKPORTPVID: Block 3/1 on xmtting vlan 202 for inc peer vlan
2006 Apr 20 17:28:25 utc +08:00 %SPANTREE-2-RX_BLKPORTPVID: Block 3/1 on rcving vlan 114 for inc peer vlan 202
2006 Apr 20 17:28:25 utc +08:00 %SPANTREE-2-RX_1QPVIDERR: Rcved pvid_inc BPDU on 1Q port 3/1 vlan 114
1 ACCEPTED SOLUTION
Re: help,is it a protocol problem?
Hi Friend,
Yes this could be an issue as connecting a hub or even a cross over cable between 2 ports in different vlans can result in this kind of problem and to be frank it is really difficult to find out in a big network.
You just need to check the errors and follow the ports and trace it out.
Check this link for all kind of spanning tree error messages and what they mean and how to troubleshoot them. This link has all the errors which were reported in your logs
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_system_message_guide_chapter09186a008009e7a1.html#353669
HTH, if yes please rate the post.
Ankur
Hi Friend,
I already tried to put it into your last post. No its not a protocol problem and mostly the problem is with configuration.
Anways can you check the native vlan config on the trunk ports? Or is possible post the config for trunk from both the switches
Ankur
Community Member
distribute layer switch:
hqjr12_cat3550_1#show int trunk
Port Mode Encapsulation Status Native vlan
Fa0/3 on 802.1q trunking 1
Fa0/4 on 802.1q trunking 1
Fa0/5 on 802.1q trunking 1
Fa0/6 on 802.1q trunking 1
Fa0/11 on 802.1q trunking 1
Fa0/12 on 802.1q trunking 1
Fa0/13 on 802.1q trunking 1
Fa0/16 on 802.1q trunking 1
Fa0/18 on 802.1q trunking 1
Gi0/1 on 802.1q trunking 1
core layer switch:
CNC-6506-L2-1> (enable) show port trunk
* - indicates vtp domain mismatch
1/1 on dot1q trunking 1
3/1 on dot1q trunking 1
3/3 on dot1q trunking 203
3/8 on dot1q trunking 1
15/1 nonegotiate isl trunking 1
16/1 nonegotiate isl trunking 1
Hi Friend,
I think you are getting an error on
3/1 on dot1q trunking 1 on different switch
Can you paste the complete config related to these ports from the 2 switches? as what all vlans are allowed on the trunks and other stuff , just paste all port related configs for these 2 ports only.
Ankur
Community Member
the native vlan is the same,however the crisis stop after all the clerk left,i thought it's not a misconfigeration,maybe someone connect two vlan togather using a hub or something,am i right?
could you tell me how can i find it,which kind of command is useful for me or send me a link,
thank you my dear friend
Hi Friend,
Ankur
404
