help me ,about the ciscoworks 2k
when I finished the installation of CW2K,it can't be display,if in client's IE(installed JAVA J2SE&JAVA VM),input
http://server:1741,then the IE will generate an error and close.if in server(also installed java vm&java j2se),the the error is:
www.ciscofan.com/cw.jpg
www.ciscofan.com/cw1.jpg
the server's configuration is :
P4 1.7G/640M DRAM/15G HD/ENGLISH Version WINDOWS ADVANCED SERVER with sp3.JAVA'S Version are all 1.41 or 1.31(the same in client and server),help!
Anonymous
N/A
Re: help me ,about the ciscoworks 2k
CW2000 only works with Java plugin 1.3.1
Not supported on Advanced server - check Release Notes on CCO.
SP 3 not supported
- Try this:
Remove JPI 1.4.1 from the client and connect to CW2000
JPI 1.3.1 will download to client and hopefully resolve your issue.
JPI 1.4.1 does not work...
Blue
Next version of CW2K will support Win2K Adv Server and SP3.
80
