Help me, Cisco7206VXR,High CPU utilization
Hi,everyone,What's wrong of my 7206VXR???
CPU utilization for five seconds: 48%/12%; one minute: 48%; five minutes: 48%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 21896 957655 22 0.00% 0.00% 0.00% 0 Load Meter
2 8786108 29953698 293 0.14% 0.10% 0.11% 0 OSPF Hello
3 1156880 491123 2355 0.00% 0.01% 0.00% 0 Check heaps
4 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
5 188 505 372 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
8 301028 4123589 73 0.00% 0.00% 0.00% 0 EnvMon
9 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
10 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
11 44224 4123590 10 0.00% 0.00% 0.00% 0 IPC Periodic Tim
12 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
13 5236 81513 64 0.00% 0.00% 0.00% 0 ARP Input
14 40184 1067494 37 0.00% 0.00% 0.00% 0 HC Counter Timer
15 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
16 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
17 0 2 0 0.00% 0.00% 0.00% 0 Entity MIB API
18 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
19 376 27466 13 0.00% 0.00% 0.00% 0 Critical Bkgnd
20 394700 1282597 307 0.00% 0.00% 0.00% 0 Net Background
21 0 108 0 0.00% 0.00% 0.00% 0 Logger
22 719218932 4123584 174424 34.73% 35.83% 36.03% 0 TTY Background
23 99784 4123591 24 0.00% 0.00% 0.00% 0 Per-Second Jobs
24 0 1 0 0.00% 0.00% 0.00% 0 CSP Timer
Gold
Re: Help me, Cisco7206VXR,High CPU utilization
The TTY process is what's eating your processor utilization. Are you running a lot of commands on the router? Are you telnetted in, or console'd? Is there someone else telnetted in, running commands? It could also be PPP sessions terminating on this router from dial in users, I think, but I don't know if those are counted under TTY or not.
Most likely, nothings wrong at all, once the telnet processes are stopped.
Russ.W
Silver
what code are you running ?
Many Thanks, I have pass the problem. at my line aux 0 port,it has a modem discovery command. remove it ,CPU utilization changed to lower........
159
