Help me protect my LAN?
Hi guys,
I read the latest 2600 and it made me nervous. It said there was a way for hackers to attack a cisco router with a flood attack and put it into a mode where all the router will do is route packets and drop its security. The hacker can then pull the config file and have their way with your network.
That being said, I went out and bought the book "Hardening Cisco Routers" and tried to follow it to the best of my abilities. I am just a student, not a professional so, please bear with me.
Here is a copy of my current config:
Current configuration : 1304 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname
enable secret 5
ip subnet-zero
no ip source-route
no ip bootp server
interface Ethernet0
ip address dhcp
no ip proxy-arp
ip nat outside
interface Ethernet1
no ip proxy-arp
ip nat inside
ip nat inside source list 1 interface Ethernet0 overload
no ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
banner login ^C
WARNING!!!
This system is soley for the use of authorized users for official purposes.
You have no expectation of privacy in its use and to ensure that the system
is functioning properly, individuals using this computer system are subject
to having all of their activities monitored and recorded by system
personnel. Use of this system evidences an express consent to such
monitoring and agreement that if such monitoring reveals evidence of
possible abuse or criminal activity, system personnel may provide the
results of such monitoring to appropriate officials.
^C
line con 0
password
login
line vty 0 4
exec-timeout 0 1
no login
no exec
transport input none
end
I don't see anything in here that will defeat a flood attack. Can anyone offer any suggestions to help make my router even more impervious to attack?
Thanks, Chris
  • Other Network Infrastructure Subjects
Silver
Re: Help me protect my LAN?
Chris,
There are thousands of different type of attacks and a different remedy for most of them. I would recommend starting with the basics, which you can do with the router and code you are running. The following is a link to NSA (National Security Agency) with security hardening recommendations for Cisco routers. http://nsa1.www.conxion.com/cisco/download.htm
Different exploits (Code Red Virus for example) took advantage of router's fast switching cache by the amount of connections it would attempt to setup. Enabling CEF would help your router's memory.
After you do your risk assesment and determine what your risk is and what you're trying to protect you might find that you want to look into the Firewall Feature set, TCP-Intercept, CBAC, SSH, and other security enhancements that have been put into IOS.
Here is a link on TCP syn type DOS attacks that might help you:
http://www.cisco.com/en/US/partner/tech/tk648/tk364/technologies_tech_note09186a00800f67d5.shtml
Looks like your doing a pretty good job so far from your configuration...
Hope this helps,
Don
Thank you for you response.
I did get a copy of the IOS feature set but, I still have to figure out how to use it. :) I am also still trying to figure out the proper use of access lists. If anyone could suggest any good books on either topic, I would be in their debt.
2600 is a scary mag. They make it sound so easy! But, I guess it can't be or the whole internet would ground to a halt.
Of all the networking topics I have studied, security is definitly the most interesting.
Silver
Here is a good link for ACL basics. Getting on CCO and searching on Access-list or access lists, or ACL will lend a lot of information for you on this.
http://www.cisco.com/en/US/partner/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml
Hope this helps,
Don
A flood Attack is difficult, but there a few things that is the best practice in security. Remember: Attack is not quite that simple, and follow not only availability, but confidentiality and integrity.
Add this lines on your config:
no service finger
service tcp-keepalives-in
service tcp-keepalives-out
aaa new-model
aaa authentication login default local
enable secret 5 $1$/fJS$XZJDfMrV4ksikDch4yrCL.
username whatever password 7 0538030C731C1E58150400
interface Ethernet
no ip redirects
no ip unreachables
no ip directed-broadcast
no ip proxy-arp
access-list 101 deny udp any any eq bootps log
access-list 101 deny udp any any eq bootpc log
access-list 101 deny udp any any eq tftp log
access-list 101 deny udp any any eq 79 log
access-list 101 deny udp any any eq sunrpc log
access-list 101 deny udp any any eq netbios-ns log
access-list 101 deny udp any any eq netbios-dgm log
access-list 101 deny udp any any eq snmp log
access-list 101 deny udp any any eq snmptrap log
access-list 101 deny udp any any eq 194 log
access-list 101 deny udp any any eq biff log
access-list 101 deny udp any any eq who log
access-list 101 deny udp any any eq 531 log
access-list 101 deny udp any any eq 540 log
access-list 101 deny udp any any eq 541 log
access-list 101 deny udp any any eq 1024 log
access-list 101 deny udp any any eq 2419 log
access-list 101 deny udp any any eq 4733 log
access-list 101 deny udp any any eq 2049 log
access-list 101 deny udp any any eq 31337 log
access-list 101 deny udp any any eq 4000 log
access-list 101 deny tcp any any eq 67 log
access-list 101 deny tcp any any eq 68 log
access-list 101 deny tcp any any eq 69 log
access-list 101 deny tcp any any eq finger log
access-list 101 deny tcp any any eq sunrpc log
access-list 101 deny tcp any any eq 135 log
access-list 101 deny tcp any any eq 137 log
access-list 101 deny tcp any any eq 138 log
access-list 101 deny tcp any any eq 139 log
access-list 101 deny tcp any any eq 161 log
access-list 101 deny tcp any any eq 162 log
access-list 101 deny tcp any any eq irc log
access-list 101 deny tcp any any eq exec log
access-list 101 deny tcp any any eq login log
access-list 101 deny tcp any any eq cmd log
access-list 101 deny tcp any any eq 531 log
access-list 101 deny tcp any any eq 541 log
access-list 101 deny tcp any any eq uucp log
access-list 101 deny tcp any any eq 12345 log
access-list 101 deny tcp any any eq 12346 log
access-list 101 deny tcp any any eq 2001 log
access-list 101 deny tcp any any eq 2002 log
access-list 101 deny tcp any any eq 4000 log
access-list 101 deny tcp any any eq 5190 log
access-list 101 deny tcp any any eq 4001 log
access-list 101 deny tcp any any eq 6001 log
access-list 101 deny tcp any any eq 6002 log
access-list 101 deny udp any any eq 1080 log
access-list 101 deny igmp any any log
access-list 101 deny gre any any log
access-list 101 deny igrp any any log
access-list 101 permit ip any any
Apply this acc with access-group 101 in on Ethernet0, wich is the outside interface of NAT.
Regards.
118
