help me: why isdn backup line doesn't work
lihuaiyu543200
hi, please help me.
the backup line between our company and branch office doesn't work. the following is debug result:
11w1d: Channel ID i = 0x89
11w1d: ISDN BR0/0: received HOST_PROCEEDING call_id 0x8462
11w1d: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xEA
11w1d: Cause i = 0x8492 - No user responding
11w1d: ISDN BR0/0: received HOST_DISCONNECT call_id 0x8462
11w1d: ISDN BR0/0: Event: Call to 38490132 was hung up.
11w1d: ISDN BR0/0: process_disc_ack(): call id 0x8462, ces 1, call type DATA
11w1d: BRI0/0: wait for isdn carrier timeout, call id=0x8462
11w1d: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x6A
11w1d: Cause i = 0x8092 - No user responding
11w1d: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xEA
11w1d: ISDN BR0/0: received HOST_DISCONNECT_ACK call_id 0x8462
11w1d: ISDN BR0/0: HOST_DISCONNECT_ACK: call type is DATA
11w1d: BRI0/0 DDR: Dialing cause ip (s=192.168.20.241, d=192.168.25.95)
11w1d: BRI0/0 DDR: Attempting to dial 38490132
11w1d: ISDN BR0/0: Outgoing call id = 0x8463, dsl 0
11w1d: ISDN BR0/0: Event: Call to 38490132 at 64 Kb/s
11w1d: ISDN BR0/0: process_bri_call(): call id 0x8463, called_number 38490132, s
peed 64, call type DATA
11w1d: CC_CHAN_GetIdleChanbri: dsl 0
11w1d: Found idle channel B1
11w1d: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x6B
11w1d: Bearer Capability i = 0x8890
11w1d: Channel ID i = 0x83
11w1d: Called Party Number i = 0x80, '38490132'
11w1d: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xEB
11w1d: ISDN BR0/0: received HOST_PROCEEDING call_id 0x8463
11w1d: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xEB
11w1d: ISDN BR0/0: received HOST_DISCONNECT call_id 0x8463
11w1d: ISDN BR0/0: process_disc_ack(): call id 0x8463, ces 1, call type DATA
11w1d: BRI0/0: wait for isdn carrier timeout, call id=0x8463
11w1d: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x6B
11w1d: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xEB
11w1d: ISDN BR0/0: received HOST_DISCONNECT_ACK call_id 0x8463
11w1d: BRI0/0 DDR: Dialing cause ip (s=192.168.20.243, d=192.168.25.73)
11w1d: ISDN BR0/0: Outgoing call id = 0x8464, dsl 0
11w1d: ISDN BR0/0: process_bri_call(): call id 0x8464, called_number 38490132, s
11w1d: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x6C
11w1d: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xEC
11w1d: ISDN BR0/0: received HOST_PROCEEDING call_id 0x8464
11w1d: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xEC
11w1d: ISDN BR0/0: received HOST_DISCONNECT call_id 0x8464
11w1d: ISDN BR0/0: process_disc_ack(): call id 0x8464, ces 1, call type DATA
11w1d: BRI0/0: wait for isdn carrier timeout, call id=0x8464
11w1d: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x6C
11w1d: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xEC
11w1d: ISDN BR0/0: received HOST_DISCONNECT_ACK call_id 0x8464
11w1d: BRI0/0 DDR: Dialing cause ip (s=192.168.20.241, d=192.168.25.92)
11w1d: ISDN BR0/0: Outgoing call id = 0x8465, dsl 0
11w1d: ISDN BR0/0: process_bri_call(): call id 0x8465, called_number 38490132, s
11w1d: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x6D
11w1d: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xED
11w1d: ISDN BR0/0: received HOST_PROCEEDING call_id 0x8465
11w1d: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xED
11w1d: ISDN BR0/0: received HOST_DISCONNECT call_id 0x8465
11w1d: ISDN BR0/0: process_disc_ack(): call id 0x8465, ces 1, call type DATA
11w1d: BRI0/0: wait for isdn carrier timeout, call id=0x8465
11w1d: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x6D
11w1d: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xED
11w1d: ISDN BR0/0: received HOST_DISCONNECT_ACK call_id 0x8465
11w1d: BRI0/0 DDR: Dialing cause ip (s=192.168.20.5, d=192.168.25.126)
11w1d: ISDN BR0/0: Outgoing call id = 0x8466, dsl 0
11w1d: ISDN BR0/0: process_bri_call(): call id 0x8466, called_number 38490132, s
11w1d: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x6E
11w1d: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xEE
11w1d: ISDN BR0/0: received HOST_PROCEEDING call_id 0x8466
11w1d: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xEE
11w1d: ISDN BR0/0: received HOST_DISCONNECT call_id 0x8466
11w1d: ISDN BR0/0: process_disc_ack(): call id 0x8466, ces 1, call type DATA
11w1d: BRI0/0: wait for isdn carrier timeout, call id=0x8466
11w1d: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x6E
11w1d: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xEE
11w1d: ISDN BR0/0: received HOST_DISCONNECT_ACK call_id 0x8466
sh2620#
our company router's config is:
User Access Verification
Password:
sh2620>en
Password:
sh2620#show run
Building configuration...
Current configuration:
version 12.0
hostname sh2620
enable secret level 14 5 $1$DHqe$itwTTozgu9KV4rXp5jAN70
enable secret 5 $1$jExL$0NKOWKGq3xl7uyZVsDJGN/
username sha_intl_express password 7 0509070C2A595E05100B12
username shanghai-pd-airport1720 password 7 070C285F4D06
ip subnet-zero
isdn switch-type basic-dms100
isdn voice-call-failure 0
interface FastEthernet0/0
ip address 192.168.20.253 255.255.255.0
no ip directed-broadcast
duplex auto
speed auto
interface BRI0/0
description ISDN local backup line 32160597
ip address 192.168.23.130 255.255.255.192
encapsulation ppp
ip ospf demand-circuit
load-interval 30
dialer idle-timeout 30
dialer map ip 192.168.23.132 name sha_intl_express 32160075
dialer map ip 192.168.23.131 name shanghai-pd-airport1720 38490132
dialer-group 1
isdn switch-type basic-net3
ppp authentication chap
router ospf 100
redistribute connected
redistribute static
network 192.168.20.0 0.0.0.255 area 0
network 192.168.23.0 0.0.0.255 area 4
network 192.169.23.0 0.0.0.255 area 4
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.20.254
ip route 192.168.21.0 255.255.255.0 192.168.23.132 200
ip route 192.168.25.64 255.255.255.192 192.168.23.131 200
no ip http server
dialer-list 1 protocol ip permit
line con 0
transport input none
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 01070706570E5708
login
no scheduler allocate
end
our branch office router config is:
shanghai-pd-airport1720#show run
version 12.0
hostname shanghai-pd-airport1720
enable secret 5 $1$vAkw$gqxcUBTWP/3aXnplgxz9E.
enable password 7 091D1C5A4D50
username sh2620 password 7 01100F175804
memory-size iomem 25
ip subnet-zero
process-max-time 200
interface BRI0
description backup line 38490132 to SH H.Q
ip address 192.168.23.131 255.255.255.192
encapsulation ppp
load-interval 30
dialer string 32160597
dialer hold-queue 75
dialer load-threshold 5 either
dialer-group 1
ip address 192.168.25.65 255.255.255.192
router ospf 100
redistribute static
network 192.168.25.0 0.0.0.255 area 4
network 192.168.204.0 0.0.0.255 area 4
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.204.1
ip route 0.0.0.0 0.0.0.0 192.168.23.130 200
ip route 192.168.23.128 255.255.255.192 BRI0
no ip http server
line con 0
password 7 1446405858
login
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 111D18071B17
login
end
6 Replies 6
samsam_wang
how do you test it? shutdown the primary link? if it is, the isdn would not work.
i use floating route, do it is not necessary to shutdown the primary link. the other isdn backup line with the same config can work well. you can see the config in our company router config.
We see the remote end switch disconnect the call stating:
84 - From the public network near the remote user (remote telco switch).
Ensure the ISDN status is fine at the remote end.
ISDN disconnect code:
http://cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
Thanks,Mak.
thanks for your help!
can you make a detail description for something that i need to check.
i have changed a new modem and i have use telephone to call to center with normal result. what else should i do?
i can not ping successfully from center to remote office, but if i ping from remote office to our center with a extended ping of a long time, the connection can be established successfully. after the long time ping is over, the connection is down and i cannot ping from center to remote.
can you lead me to solve it? thank you!
as mark already told you, the branch router doesn´t respond to the isdn call.
Maybe its the wrong number, so it is ringing somewhere but not on the isdn port of the router.
If you dial from the branch-router to the central-site you can do a "debug isdn q931" on the central-router and look at the "calling-number".
This should be the same as the number you have to dial except some preceding digits for dialing out or long-distance calls or whatever the ...
good luck
Horst
thank you very much! i will have a check.
