HELP Monitor port 761 router
Help
I need to configfure two 761 routers before tomorrow. Its 9pm here.
Im trying to find the pinouts to make a console cable.
db9 to db9
hope someone can help
regards
Simon
Re: HELP Monitor port 761 router
thanks for your reply.
clicked on the link and it says im not logged in even though i had to be to post the thread in the forum.
only registered this afternoon.
is there something im missing
thanks Bo
Try dis...
Specifications
Downloads
Specifications
Table of Contents
Specifications
Router Specifications
Port Pinouts
Ethernet Port
Serial Configuration Port
Power Connector
Common Port Assignments
Specifications
This chapter provides the specifications for your router and companion equipment.
The specifications for Cisco 700 series routers are listed in Table A-1.
Table A-1: Hardware Specifications Description Design Specification
Height x Width x Depth
1.6 x 8.3 x 9.6 in. (4.1 x 21.1 x 24.4 cm)
Weight
Cisco 761 and Cisco 771: 1.4 lb. (0.6 kg)
Cisco 762 and Cisco 772: 1.5 lb. (0.7 kg)
Cisco 765 and Cisco 775: 1.6 lb. (0.7 kg)
Cisco 766 and Cisco 776: 1.7 lb. (0.8 kg)
Power supply
Voltage
Frequency
External
100 or 250 VAC
50 to 60 Hz
Processor
25-MHz 80386
Memory
1.5 MB of primary memory
1.0 MB of Flash memory
16 KB of NVRAM
Operating temperature
32 to 120ºF (0 to 50ºC)
Storage temperature
-30 to 160ºF (-35 to 70ºC)
Operating humidity
20 to 95%, noncondensing
Warning
Ultimate disposal of this product should be handled according to all national laws and regulations.
Port Pinouts
The router ports are industry standard, unless otherwise noted in this section. Figure 1-3 in "Overview," lists the ports by model.
Ethernet Port
Table A-2 compares the pinouts of the Ethernet port depending on the position of the HUB/NODE switch.
Table A-2: Ethernet Connector Pinouts (RJ-45) Pin Function (HUB/NODE switch in HUB Position) Function (HUB/NODE Switch in NODE Position or the Unmanaged Hub on Cisco 766 and 776 routers)
TX+
RX+
TX-
RX-
RX+
TX+
Unused
Unused
Unused
Unused
6
RX-
TX-
7
Unused
Unused
8
Unused
Unused
Table A-3 shows the pinouts for the configuration port.
Table A-3: Configuration Port Pinouts (DB-9) Pin Function
Carrier Detect (CD)
Received Data (RXD)
Transmitted Data (TXD)
Data Terminal Ready (DTR)
Signal Ground
6
Data Set Ready (DSR) input
7
Not used
8
Not used
9
Not used
The console port is configured as a data communications equipment (DCE) device. The default parameters for the console port are as follows:
Bits per second = 9600
Data bits = 8
Parity = None
Stop bits = 1
Power Connector
Table A-4 shows the pinouts for the router power connector, and, Figure A-1 shows the location of the power connector pins.
already found that, but what im looking for it the db9-db9 connections.
ie pin 2 - pin3
pin 3 - pin2
pin5 - pin5
etc
thanks
thanks for everyones help
got it sorted bt trial and error.
the cable needed is straight through
thanks again
simon
109
