Help needed booting up a cisco 2503
Hello all,
I recently purchased a 2503 and when I try to load the router, it gets stuck on this message :
"00:01:29: %SNMP-5-COLDSTART: SNMP agent on host r4 is undergoing a cold start"
I am unable to type anything at all on the keyboard, I have also let the router on over night to see if the message goes away but its the same. I tried a break when first loading the router and I got the > prompt after the break, but i was unable to enter any comands like before. Here is what it says on bootup.
ÿ
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
2500 processor with 16384 Kbytes of main memory
%SYS-4-CONFIG_NEWER: Configurations from version 12.2 may not be correctly under
stood.
F3: 14812760+965484+917464 at 0x3000060
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 2500 Software (C2500-JS-L), Version 12.2(12), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 21-Aug-02 05:48 by pwade
Image text-base: 0x0307B07C, data-base: 0x00001000
cisco 2500 (68030) processor (revision A) with 16384K/2048K bytes of memory.
Processor board ID 01167130, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Press RETURN to get started!
00:00:10: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
00:00:10: %LINK-3-UPDOWN: Interface Serial0, changed state to down
00:00:10: %LINK-3-UPDOWN: Interface Serial1, changed state to down
00:00:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed sta
te to down
00:00:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to down
00:00:44: %LINK-5-CHANGED: Interface BRI0, changed state to administratively dow
n
00:00:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0, changed state to
down
00:00:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state
to down
00:00:45: %SYS-5-CONFIG_I: Configured from memory by console
00:01:29: %SYS-5-RESTART: System restarted --
Any suggestions? Thanks for the help in advance.
1 ACCEPTED SOLUTION
Re: Help needed booting up a cisco 2503
This is a notification message only.
I suspect in the console connection.
Please check the baud rate of the serial port while connecting the router to the console port .
-Deepu
What are you using to connect to console? NT/Win2k have caused me trouble in past. Try doing a cold boot on system running terminal program then boot router.
-Deepu
thanks for that suggestion, the rate was set at 9600, but i played around a bit and It lets me enter commands if i set the flow control to off. Thanks again, this one was bugging me for a while.
104
