Webcast-Catalyst9k
Help needed Cisco 3660
Greetings Cisco Experts,
I’m trying to connect two Cisco 3660 back-back using VWIC-2MFT-E1 (RJ 48 cross over)
Cisco 3660(VWIC-2MFT-E1)=====(VWIC-2MFT-E1)Cisco3660
One of the VWIC-2MFT-E1 is in the 2W slot and the other is in the 2FE-2W slot
But for some reasons both of them are not talking to each other and I’m getting
A lot of slip alarms on the controllers
Following is the simple config of both routers
Router 1
controller E1 5/0
shutdown
framing NO-CRC4
clock source free-running
controller E1 5/1
framing NO-CRC4
clock source internal
channel-group 1 timeslots 1-31
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial4/0
no ip address
shutdown
interface Serial4/1
no ip address
shutdown
interface Serial4/2
no ip address
shutdown
interface Serial4/3
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet5/1
no ip address
shutdown
duplex auto
speed auto
interface Serial5/1:1
ip address 10.160.63.22 255.255.255.252
router eigrp 1
network 10.160.63.20 0.0.0.3
auto-summary
no eigrp log-neighbor-changes
E1 5/1 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20000922, FPGA: 15
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Internal.
Current port master clock: local osc on this network module
Data in current interval (191 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
191 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
191 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Router 2 Config
controller E1 5/1
framing NO-CRC4
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
clockrate 2015232
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
ip address 10.160.63.21 255.255.255.252
router eigrp 1
auto-summary
E1 5/1 is up.
No alarms detected.
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Current port master clock: recovered from controller 5/1
Data in current interval (868 seconds elapsed):
1 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
Thanks in Advance
aht
Re: Help needed Cisco 3660
For the VWICs I think you need to configure the channel group command with the speed option specified as follows.
channel-group 1 timeslots 1-31 speed 64
This will use each DS0 channel at 64K. Default value is 56Kbps if you do not specify the speed option.
Hope that helps!
thisisshanky,
Thank you very much for the quick reply
Yes I already configured that as 64 but still didn't work.
In one of the manual I found that VWIC-2MFT-E1 has
built in DSU but not CSU,so I'm not sure whether
can I connect them back to back,or should I connect to it a third party CSU to give clocking to it.
Any ideas will be highly appreciated
aht
By default for E1 channel speed is 64k, so that is not the problem.
I think u will have to change the clocking for one side to clock source line and the other to internal.
Also u can connect VWICs back to back, no problem
Jawwad
jawwadh19@yahoo.com
173
