Help needed with ddr isdn backup with rotary groups
Hi There,
I'm trying to backup several remote sites' wan connection with isdn to a central site ( a hub and spoke topology for ddr backup). I want the remote sites to call the central site when the wan link goes down but not the other way round. The central site has a pri E1 connection to a 3640 router. I have configured dialer watch at the remote site and it works ok when the central site is configured with a dialer group command and dialer remote name. I wanted to use rotary groups so that i can add more remote sites to the dialer profile config at the central site ( i was going to add more dialer map statements to the dialer interface as shown in my enclosed config).
With the rotary group and dialer map statement configured on the central site I am unable to get ip connectivity between the central and remote site. The remote router shows an isdn connection to the central site when i do 'show dialer' but pings don't show connectivity. This is the central site config:
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname trr004x
enable password 7 xxxxxxxxxx
username master password 7 xxxxxxxxx
username MRR001X password 7 xxxxxxxx
username CCR001X password 7 xxxxxxxxx
ip subnet-zero
no ip domain-lookup
ip host mrr001x 10.1.16.2
isdn switch-type primary-net5
clock timezone gmt 0
clock summer-time bst recurring last Sun Mar 2:00 last Sun Oct 2:00
controller E1 2/0
pri-group timeslots 1-31
interface Ethernet0/0
description link to trf0021 mod 2 port 5
ip address 10.2.44.4 255.255.252.0
no ip directed-broadcast
interface Ethernet0/1
no ip address
shutdown
interface Serial2/0:15
no ip address
encapsulation ppp
dialer rotary-group 1
interface Dialer0
ip address 10.2.176.1 255.255.255.0
encapsulation ppp
dialer in-band
dialer map ip 10.2.176.10 name MRR001X
dialer-group 1
ppp authentication chap
ppp multilink
interface Dialer1
no ip address
encapsulation ppp
pulse-time 0
router eigrp 1
network 10.0.0.0
network 144.98.0.0
no auto-summary
ip classless
map-class dialer remote
dialer wait-for-carrier-time 60
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
line con 0
transport input none
line aux 0
line vty 0 4
password 7 xxxxxxxxxxxx
login
end
Here is the configuration of the remote router:
Building configuration...
Current configuration : 4095 bytes
! Last configuration change at 13:00:30 bst Wed Aug 7 2002 by master
! NVRAM config last updated at 12:24:29 bst Wed Aug 7 2002 by master
version 12.1
service timestamps debug datetime
service timestamps log datetime
service udp-small-servers
service tcp-small-servers
hostname MRR001X
boot system flash
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication ppp default local
aaa authorization exec default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
enable secret 5 xxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxxxxxxxxxxxx
username trr004x password 7 08324D5D0A49
ip subnet-zero
isdn switch-type basic-net3
isdn voice-call-failure 0
isdn tei-negotiation first-call
interface Ethernet0
ip address 10.28.0.1 255.255.252.0
ip helper-address 10.2.44.200
no ip route-cache
no ip mroute-cache
keepalive 4
interface Serial0
description Frame-Relay Link from MRR001X to TRR001X
bandwidth 64
ip address 10.1.16.2 255.255.255.252
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
no fair-queue
frame-relay map ip 10.1.16.1 100 broadcast
frame-relay lmi-type ansi
interface Serial1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface BRI0
description dial backup link to trr004x
bandwidth 56
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
no keepalive
dialer pool-member 1
no fair-queue
no cdp enable
interface Dialer0
ip address 10.2.176.10 255.255.255.0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer remote-name trr004x
dialer idle-timeout 90
dialer string 01xxxxxxxxx
dialer watch-group 8
dialer-group 1
no fair-queue
no cdp enable
ppp multilink
router eigrp 1
network 10.0.0.0
network 144.98.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
no ip http server
logging trap debugging
access-list 101 deny ip any any
dialer watch-list 8 ip 10.1.16.0 255.255.255.252
dialer-list 1 protocol decnet deny
tacacs-server host 10.2.44.208
tacacs-server host 10.2.44.206
tacacs-server timeout 1000
tacacs-server key cisco
snmp-server engineID local 00000009020000E01E3E7080
snmp-server community public xxxx
line con 0
line aux 0
password cisc0
no activation-character
modem InOut
transport input all
stopbits 1
flowcontrol hardware
line vty 0 4
password xxxxxx
ntp clock-period 17179828
ntp server 144.98.31.172
end
Hope you can help me show where I have gone wrong, rgds Martin
Re: Help needed with ddr isdn backup with rotary groups
Instead of using dialer map under dialer interface, Try using it under physical interface (under interface serial 2/0:15) without "dialer rotary-group 1" command..You can use as many dialer map you want under that serial 2/0:15 interface..So just configure that serial interface for ip address and dialer map for remote sites..(like dialer interface)
OR
Since all the remote sites are coming up with a static ip address, you don't even need a dialer map statements..Let the central site make a dynamic dialer map after ppp negotiation.
Try aboce config and see if you can get success
i'll give that a go and let you know, thanks for the advice.
Taking out the dialer map statement from the dialer profile has got it working, thanks for the advice. Just another 28 remote sites to set-up and test now that the first is is working! Ho-hum.
84
